tintdude.com logo
Wagner Wallpaper Steamer
TTS
Questions for those that use the Wagner wallpaper steamer from HD....
1) does it REALLY take 20 minutes to start to work as stated on the box ???
2) Which attachment do you use at the end of the hose for steam'n off film ? Do you use one of the 'bricks' it comes with ??
Thanks...
1PEECBARETTA
1 yes
2 none, just end of ho's
TTS
Thanx for the reply! ....... I don't know if I am patient enough to wait 20 minutes for the warm-up... (I was hope'n in reality it was quicker) rollin.gif
WASHBOY
I have two steamer, forget witch ones but they heat up quick! Twenty mins is way too long, mine is ready in 2-5min depending on the weather!
willie
(WASHBOY @ Jan 24 2008, 10:10 PM) [*]584464[/*]
Mine can be ready a whole lot quicker, it depends on the chick Ninja-Invisible.gif
ClassOnGlass
i use a cheap conair from wall mart it heats up in about 5 to 10 mins topps and once shes going it pumps out some steam man thumb.gif
TTS
Tintmart
hmmm 20-25min i dont think so, then again i always put hot water in it so heats up alot quicker
cartek
i have never steamed tint off of a car, do you just steam over the current tint and then peel? does it work that well, i am going to be upset if it works well and i waited til this long.
but i am still curious as to whether you just steam right over the $hitty purple tint and pull it off, or is it still a pain in the neck?
thanks
Get It Darker
So far i have untinted 2 cars with steam and have come off very clean. I use an old shark steamer bought at a garage sale for $5 and work like magic. The main thing is to take your time on dot matrix or else you will have glue which might be hard to take off on BG. wall.gif
ClassOnGlass
i got a cheap conair its steaming in 5 to 10 tops 30 bucks walmart
TITAN500
(CCNW @ Jan 19 2008, 11:12 AM) [*]581630[/*]
Thanks...
it takes forever to heat up
didnt use an attachment
heats up to flesh burning magma temp
spits out scalding hot water intermittently along with steam
still have burn scars on my forearm from happy adventures of fun and excitement with the wagner wall paper steamer
have since moved on to a Reliable t 730 A steamer
micro-edge
(TITAN500 @ Apr 10 2008, 01:26 PM) [*]612772[/*]
Thanks...
bingo.gif Flaugh.gif The wagner will spit some boiling hot water out from time to time. If you fill it only half way it heats up alot quicker and doesn't spit at you as much but a jiffy steamer is the professionals choice thumb.gif
TTS
Thanks for all the info!
I already had a jiffy and was just thinking of a backup/ 2nd unit.... I ended up sticking w/ jiffy thumb.gif
flat rock stan
(TTS @ Apr 10 2008, 12:18 PM) [*]612801[/*]
I'v got a couple of new Jiffys in inventory across town from ya if you need one I will make you a deal.
TTS
thumb.gif Thanks Stan.. I'll keep that in mind
CleanCutter
the Conair steamer from Walmart works just as well as any of my Jiffy Steamers ever have - and it wasn't but all of about $40 I think.
I bought one when in a pinch far away from the shop and badly needed to get some film off very large and fragile windows. Was skeptical about it at first, but if it ever burns up, I'll buy another before the Jiffy. Mine heats up in about a minute or so and is hotter than Hades and spits out a pretty heavy flow of steam.
The large steam head it comes with isn't real great for getting film off tight places on a car (works fine on flat glass), but for a $40 steamer, you won't feel bad about cutting the end of the hose off and modifying it to use a single outlet tube like a Jiffy (and you'll probably want to make the hose a touch longer) - or not, you can take the steamer body with you into the car ... so not much need for a really long hose (you just take the hose stand off the body).
Contact: tintdude[a]gmail.com
