cutting film
Full Version: cutting film
when cutting the patern for the glass who peels the liner then sticks it on the glass then cuts it out , and then who just cuts the film on the glass with the liner still on, then cuts it out and pulls the liner than apply?
when I started doing this I used to precut everything with the liner on, now it depends on the specific window...
deeper frames if dirty I precut, clean and not deep - stick then cut I try to opt for the cleaner and faster way to do it (dan_kohan @ Feb 3 2008, 08:52 AM) [*]588885[/*] when cutting the patern for the glass who peels the liner then sticks it on the glass then cuts it out , and then who just cuts the film on the glass with the liner still on, then cuts it out and pulls the liner than apply? like homeboy said depends on the situation of the glass ill precut then clean n install reverse roll for big windows
The only pre cutting I ever do is with thicker s/s films like 12mil.
i reveres dry roll it on to a wet window the cut the pattern
(ClassOnGlass @ Feb 4 2008, 06:12 AM) [*]588954[/*] i reveres dry roll it on to a wet window the cut the pattern
I clean the window, no matter what it is, scrape it, spray it, dry it... I have already cut my pieces off the handler within an inch of excess on either side. After I cut them, rolll them and tape them set them aside the window Im working on. Once everything is clean, undo the tape, pull the liner (S&S) apply the film.
guess we all do it differently.. good luck (General Sun Shield @ Feb 3 2008, 12:08 PM) [*]588952[/*] The only pre cutting I ever do is with thicker s/s films like 12mil. ![]()
I usually buy from JWF , they have a pre cut program where they pre-cut per your measurements and they send you individual rolls so all you have to is reverse roll in place and then just trim as needed once is applied. I also had a 4ft x 4ft round window today and I just taped a oversized square piece of film over the round frame and cut out the circle using the round frame as a guide then reversed rolled it in place once the pattern was cut and then did the final trim. From my experience, you get a cleaner install with reverse rolling, exceptions would be very small peices, or very very large windows that requires two people to install anyways.
Nowadays I only precut the super duty old nasty windows and V-Kool (cause it's PS).
