tintdude.com logo
Viper remote start system 160xvl door lock wiring
toyota tech
I bought a viper remote start system for my moms '99 toyota camry for christmas,which i am trying to install myself. I am a toyota tech at a toyota dealership and i am having problems with the door lock wiring harness (H4). The installation guide for the model 160XVL says to refer to tech tip 1041 for wiring information. I do not have access to this information ( not a dealer or a installer ). I bought this system from Best Buy, so i talked to them about this and they said they could not help me ( funny, i fix their problems all the time ). I need to know where the 5 wires from the door lock harness connect to. Thank you for your time.
CajunTinter
Constant 12V+ White or White/Red Ignition Harness
Starter Red Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Black/Red Ignition Switch Harness
Accessory Blue/Red Tests as Ignition
Tach Yellow/Red AC Or White/Red(4+6 Cylinder) Ignition Driver's Shock Tower
Brake Switch Green/White White Connector bottom right of Fuse Panel
Trunk Release Blue/Black (+) Driver's Kick Panel
Trunk Pin Red/Yellow (-) Blue Connector Driver's Kick Panel
Parking Lights Green (+) White Connector bottom left of Fuse Panel
Head Lamp Red/Yellow (-) Steering Column Harness
Factory Disarm Red/Green (-) Driver's Kick Panel White 24 Pin Connector
Door Trigger Red/White (-) Top right of Fuse Panel White 14 Pin Connector
Door Lock Light Green (-) Driver's Kick White Connector
Door Unlock Red/Green (-) Double Pulse to Unlock
Driver's Lock Blue Left Kick Panel
Driver's Unlock Blue/Red Left Kick Panel
Passenger Unlock Dark Green Left Kick Panel
Horn Wire Green/Black (-) Orange Connector bottom Fuse Panel
Windows Up LF=Green, RF=Green/White, LR=Green/Yellow, RR=Green/Black
Windows Down LF=Red, RF=Red/Blue, LR=Red/Yellow, RR=Red/Black
Contact: tintdude[a]gmail.com
