tintdude.com logo
Arming a repo vx 160
Full Version: Arming a repo vx 160
freeky1
Hello everyone,
I recently bought a toyota corolla 2004, it is a repo. So it didn't come with the remote. I bought the remote and programmed it. However, I guess whoever repoed it, removed the arming mechanisim. When I push the arming button, the led does not flash, and when I left the window open and opened the door after 3 minutes of arming it, nothing happened. I pushed the arming button for 3 seconds, the car started flashing the signal lights but with no siren. I guess they also removed the horn connection. Does anyone know what they did to the connections of the alarm? or may be it wasn't installed from the first place?
zolar
1) the alarm is in valet mode
2) the siren wires are cut
problem solved
If you can't resolve it with these 2 solutions
wndotint
If you held the lock/arm button and the lights started flashing, it's in panic mode. But since there is no noise, siren wire/s are probably cut, like Zolar said. The LED could be cut, too. Since it was a repo, I bet the siren wires are cut but the siren is still there. Check on the fenders or the firewall.
running free
Contact: tintdude[a]gmail.com
