2005 toyota avensis
Full Version: 2005 toyota avensis
have done plenty of the old shape anything different with these??
no they are pretty straight forward.
If you take door panels off - from memory i think you'll find a deep 10mm bolt underneath the square avensis badge on the door panel. QUOTE (Tintim @ Aug 19 2008, 12:42 PM) [*]636767[/*] no they are pretty straight forward. If you take door panels off - from memory i think you'll find a deep 10mm bolt underneath the square avensis badge on the door panel. thanks alot i have 1 coming in morning
use a lil chizler to remove the badge, the panel marks easily.
QUOTE (naughtydog @ Aug 19 2008, 01:07 PM) [*]636771[/*] use a lil chizler to remove the badge, the panel marks easily. good to know cheers
got it done anyway,i just took screw out from behind door release handle and pulled panel back at top to take rubrail out,easy car 3 hours
