QUOTE (The ///Man @ Sep 6 2008, 11:39 PM) [*]640319[/*]
Some thing I do that works out pretty well is cutting the tint a bit short. I cut the bottom and bump it up maybe about 1/8" dunno exactly as I eyeball it, but then do the rest of my cuts. What this will do it acompensate for the little bit og gap at the top and make it so the bottom of the tint is right even or just barely behind the felt, not more than 1/8" down there past the felts. Then when you install the film and roll up the window, squeegee onedown the middle and across the bottom 1st to sprad the bottom out and keep from sucking up dirt in the fingers from the bottom. if the film was shrunk properly before, there shouldn't be any issues with fingers. on the sides either.
sorry if it makes no sense, I'm drinking a lil bit.
I do practically the same thing, works out great!
