66 plymouth baracuda
Full Version: 66 plymouth baracuda
Can I get a few tips on this back glass, never done one looks like fun though. Im thinkin dry & lay the sides down wet ? Any thoughts ?
here is a tip.. get someone else to do it..
ok...but seriously...looks like the top of the window is going to be the hardest part..i would seriously consider getting someone out to remove the window..it will make it easier to shrink...that is the best tip i can give you being that i have never tinted one.
oh..and another tip..charge more next time...what ever you are charging them..it isnt enough.
OMG
I did one less than 6 months ago.Here is what i did.Right were the window curves at the top(lower part of curve) i ran seam to the bottom about 3 inches in from the side corner.I think my side pieces were about 16 inches wide then one large center piece.Yah, it took 3 pieces.Install the large piece first then either side.I tried to get it one piece but I ran into problems on the sides.When I layed the film on the outside it looked like one piece would work,but it didn't.I use Llumar ATR film.It did take about 10 hours from first attempt to completion.
Did it just as planned its all shrunk, ready for install. I'm crossing my fingers
(tint_audiopros @ Nov 17 2008, 10:41 AM) [*]653406[/*] Did it just as planned its all shrunk, ready for install. I'm crossing my fingers What film? (tintgod @ Nov 17 2008, 09:20 AM) [*]653357[/*] oh..and another tip..charge more next time...what ever you are charging them..it isnt enough. (maddtinter @ Nov 17 2008, 10:40 AM) [*]653403[/*] I did one less than 6 months ago.Here is what i did.Right were the window curves at the top(lower part of curve) i ran seam to the bottom about 3 inches in from the side corner.I think my side pieces were about 16 inches wide then one large center piece.Yah, it took 3 pieces.Install the large piece first then either side.I tried to get it one piece but I ran into problems on the sides.When I layed the film on the outside it looked like one piece would work,but it didn't.I use Llumar ATR film.It did take about 10 hours from first attempt to completion. I was able to get the one piece install about 85% then it creased.The sides would not form to the curve towards the front of the car.
As I looked at the pic showing the side of the car my seams were near the same height as the chrome trim at the top of the door.
Better you than me
(filmslayer @ Nov 17 2008, 12:16 PM) [*]653421[/*] Better you than me The one i worked on the gasket was original.The car had been rescued from a ranch.It was not worth trying to replace the gasket.If the car was in better condition the customer was going to replace the gasket but he didn't.He had replaced the rear carpet kit 3 times in 10 years he was tired of the carpet fading. (maddtinter @ Nov 17 2008, 10:42 AM) [*]653407[/*] (tint_audiopros @ Nov 17 2008, 10:41 AM) [*]653406[/*] Did it just as planned its all shrunk, ready for install. I'm crossing my fingers What film? qdp-5 (maddtinter @ Nov 17 2008, 10:45 AM) [*]653410[/*] (maddtinter @ Nov 17 2008, 10:40 AM) [*]653403[/*] I did one less than 6 months ago.Here is what i did.Right were the window curves at the top(lower part of curve) i ran seam to the bottom about 3 inches in from the side corner.I think my side pieces were about 16 inches wide then one large center piece.Yah, it took 3 pieces.Install the large piece first then either side.I tried to get it one piece but I ran into problems on the sides.When I layed the film on the outside it looked like one piece would work,but it didn't.I use Llumar ATR film.It did take about 10 hours from first attempt to completion. I was able to get the one piece install about 85% then it creased.The sides would not form to the curve towards the front of the car.bingo actually got atleast 90% layed down even one whole side and top corner, the other side , the film was so stressed it wouldn't go creased on me. Im tinting all other side windows then telling customer only way is to have it removed (filmslayer @ Nov 17 2008, 11:16 AM) [*]653421[/*] Better you than me thats my guess
I hope you find the reply to your question helpful.As I said I spent WAY TOO LONG on that window.My ego was telling me not to give up.When I first started tinting over 20 years ago I learned how to overlap then butt seam.Some late model Benz SEL models I would tint with 1 large center and 2 sides doing an overlap seam.Back then either the shrinking technique was not known or I was not taught how to do it.
(tint_audiopros @ Nov 17 2008, 05:34 PM) [*]653447[/*] (maddtinter @ Nov 17 2008, 10:42 AM) [*]653407[/*] (tint_audiopros @ Nov 17 2008, 10:41 AM) [*]653406[/*] Did it just as planned its all shrunk, ready for install. I'm crossing my fingers What film? qdp-5 (maddtinter @ Nov 17 2008, 10:45 AM) [*]653410[/*] (maddtinter @ Nov 17 2008, 10:40 AM) [*]653403[/*] I did one less than 6 months ago.Here is what i did.Right were the window curves at the top(lower part of curve) i ran seam to the bottom about 3 inches in from the side corner.I think my side pieces were about 16 inches wide then one large center piece.Yah, it took 3 pieces.Install the large piece first then either side.I tried to get it one piece but I ran into problems on the sides.When I layed the film on the outside it looked like one piece would work,but it didn't.I use Llumar ATR film.It did take about 10 hours from first attempt to completion. I was able to get the one piece install about 85% then it creased.The sides would not form to the curve towards the front of the car.bingo actually got atleast 90% layed down even one whole side and top corner, the other side , the film was so stressed it wouldn't go creased on me. Im tinting all other side windows then telling customer only way is to have it removed (filmslayer @ Nov 17 2008, 11:16 AM) [*]653421[/*] Better you than me thats my guess i told you to have it removed....but i do give you props for trying it...i would have done the same. (tintgod @ Nov 17 2008, 08:48 PM) [*]653493[/*] (tint_audiopros @ Nov 17 2008, 05:34 PM) [*]653447[/*] (maddtinter @ Nov 17 2008, 10:42 AM) [*]653407[/*] (tint_audiopros @ Nov 17 2008, 10:41 AM) [*]653406[/*] Did it just as planned its all shrunk, ready for install. I'm crossing my fingers What film? qdp-5 (maddtinter @ Nov 17 2008, 10:45 AM) [*]653410[/*] (maddtinter @ Nov 17 2008, 10:40 AM) [*]653403[/*] I did one less than 6 months ago.Here is what i did.Right were the window curves at the top(lower part of curve) i ran seam to the bottom about 3 inches in from the side corner.I think my side pieces were about 16 inches wide then one large center piece.Yah, it took 3 pieces.Install the large piece first then either side.I tried to get it one piece but I ran into problems on the sides.When I layed the film on the outside it looked like one piece would work,but it didn't.I use Llumar ATR film.It did take about 10 hours from first attempt to completion. I was able to get the one piece install about 85% then it creased.The sides would not form to the curve towards the front of the car.bingo actually got atleast 90% layed down even one whole side and top corner, the other side , the film was so stressed it wouldn't go creased on me. Im tinting all other side windows then telling customer only way is to have it removed (filmslayer @ Nov 17 2008, 11:16 AM) [*]653421[/*] Better you than me thats my guess i told you to have it removed....but i do give you props for trying it...i would have done the same. (maddtinter @ Nov 18 2008, 12:02 AM) [*]653496[/*] (tintgod @ Nov 17 2008, 08:48 PM) [*]653493[/*] (tint_audiopros @ Nov 17 2008, 05:34 PM) [*]653447[/*] (maddtinter @ Nov 17 2008, 10:42 AM) [*]653407[/*] (tint_audiopros @ Nov 17 2008, 10:41 AM) [*]653406[/*] Did it just as planned its all shrunk, ready for install. I'm crossing my fingers What film? qdp-5 (maddtinter @ Nov 17 2008, 10:45 AM) [*]653410[/*] (maddtinter @ Nov 17 2008, 10:40 AM) [*]653403[/*] I did one less than 6 months ago.Here is what i did.Right were the window curves at the top(lower part of curve) i ran seam to the bottom about 3 inches in from the side corner.I think my side pieces were about 16 inches wide then one large center piece.Yah, it took 3 pieces.Install the large piece first then either side.I tried to get it one piece but I ran into problems on the sides.When I layed the film on the outside it looked like one piece would work,but it didn't.I use Llumar ATR film.It did take about 10 hours from first attempt to completion. I was able to get the one piece install about 85% then it creased.The sides would not form to the curve towards the front of the car.bingo actually got atleast 90% layed down even one whole side and top corner, the other side , the film was so stressed it wouldn't go creased on me. Im tinting all other side windows then telling customer only way is to have it removed (filmslayer @ Nov 17 2008, 11:16 AM) [*]653421[/*] Better you than me thats my guess i told you to have it removed....but i do give you props for trying it...i would have done the same. that is why you have a professional do it..or have the customer set it up with a professional glass installer/remover do it...that way...if anything goes wrong..it is on them and not you. (tintgod @ Nov 17 2008, 10:16 PM) [*]653504[/*] (maddtinter @ Nov 18 2008, 12:02 AM) [*]653496[/*] (tintgod @ Nov 17 2008, 08:48 PM) [*]653493[/*] (tint_audiopros @ Nov 17 2008, 05:34 PM) [*]653447[/*] (maddtinter @ Nov 17 2008, 10:42 AM) [*]653407[/*] (tint_audiopros @ Nov 17 2008, 10:41 AM) [*]653406[/*] Did it just as planned its all shrunk, ready for install. I'm crossing my fingers What film? qdp-5 (maddtinter @ Nov 17 2008, 10:45 AM) [*]653410[/*] (maddtinter @ Nov 17 2008, 10:40 AM) [*]653403[/*] I did one less than 6 months ago.Here is what i did.Right were the window curves at the top(lower part of curve) i ran seam to the bottom about 3 inches in from the side corner.I think my side pieces were about 16 inches wide then one large center piece.Yah, it took 3 pieces.Install the large piece first then either side.I tried to get it one piece but I ran into problems on the sides.When I layed the film on the outside it looked like one piece would work,but it didn't.I use Llumar ATR film.It did take about 10 hours from first attempt to completion. I was able to get the one piece install about 85% then it creased.The sides would not form to the curve towards the front of the car.bingo actually got atleast 90% layed down even one whole side and top corner, the other side , the film was so stressed it wouldn't go creased on me. Im tinting all other side windows then telling customer only way is to have it removed (filmslayer @ Nov 17 2008, 11:16 AM) [*]653421[/*] Better you than me thats my guess i told you to have it removed....but i do give you props for trying it...i would have done the same. that is why you have a professional do it..or have the customer set it up with a professional glass installer/remover do it...that way...if anything goes wrong..it is on them and not you.
thanks tg and everyone else for the tips & moral support. I did in fact get this car done, I did take maddtinters advice (thankyou) & did the vertical seams after trying to one piece twice wasting atlease 12' of film & the customer was actually extremely happy therefore so was I ! Will post pics tomorrow.
........well tomorrow is finally here, & heres the pictures
Way to go dude!
thanks again madd
Nice Job for a nice car
