tintdude.com logo
2 door Nissan Altima
Full Version: 2 door Nissan Altima
lilDetails
Tinted a 2009 2 door Altima Saturday and had my first real fight with the dot matrix in years. I have most dots lay down and look very nice, but this car was horrible.
It didn't want to stick first off, then I got it to start to stick a bit better with the 4th or 5th squeegee pass. Went outside to look at it and it was just nasty looking. I grabbed my trusty rubbing alcohol/ water mix, peeled back the dots, sprayed, and re-squeegeed the film again. It still was looking like trash...
After a bunch of time heating up with my heat lamps and hitting it with the heat gun as well, it began to look pretty even, but still didn't look very good. It did not look like my "normal" cars. My only relief was that they had a 2008 model up front that looked worse than mine did....so I left it.
While it looked worse than my normal, it was not as bad as most others that I see so I didn't let it bug me that much.....
Moral: Watch out for the 2 door Altima dots
lilDetails
meant to put that it is Global HP 20 film.....
maddtinter
You results will be significantly better if you use a high performance matte finish vinyl.It is very simple to do.Trim the film off on the outside then trace it over your vinyl.It makes the installation look stunning.We have been using vinyl for almost 10 years not once have I seen it fail.I can tell that you are concerned about your finished product.Try it you will love it.
tintmanlibby
ive done alot of them ! elmer's blue glue poundsand.gif or silicone
i will tell you doing the windshield on the 08's, 2 and 4 door are a pain in the fdup2.gif
I-tinted-the-pyramids
QUOTE (maddtinter @ Nov 21 2008, 09:53 AM) [*]654015[/*]
thumb.gif Yep vinyl does a fantastic job. Perfect pitch black finish. Never had a failure either.
VIP tint + glass
seriously, first the accord now this. tint it and let it go. when it dries it will be uniform. the same with the newer civics and newer altima sedans. no need for glue or vinyl. its the ones that come out not uniform that glue needs to be done.
tintmanlibby
QUOTE (VIP tint + glass @ Nov 21 2008, 12:03 PM) [*]654059[/*]
very true thumb.gif i guess i've been using glue for so long it's like habbit,but this vinal thing blow's my mind .
i can't bring myself to take a brand new car that someone just paid me $400.00 to tint and stick a vinal strip on it.
my custy's would flip out if i did that.
just image when they come out to inspect there car and they see a vinal strip.
holly stop payment on check batman,
i guess they won't be intrested in a clear bra after that,or maybe they would .they see i can already use vinnal spit.gif
but to each there own
VIP tint + glass
its trial and error. whenever youre driving around and you see a newer car look at the dots. if they are uniformlly not stuck dont do anything, these are the hardest ones to glue down. other than those ive listed and the old 97 q45's, we glue them all. some need to be sanded then glued like the mustangs. glue doesnt hold up on those. also the older honda 2 drs need special attention to get the glue to stay down.
Tint Artist
I did a 2dr Altima few weeks ago and i sanded the dots with 600 grit sand paper for about ten minutes! Cleaned the matrix area with acetone, installed the film, pulled the film off just the dots and put a heat lamp on it for 15 minutes! Put a wet paper towel around a hard card and slowly push it up inch by inch dry! Soon as the film hits that hot glass it bonds beautifully!
maddtinter
QUOTE (VIP tint + glass @ Nov 21 2008, 12:16 PM) [*]654066[/*]
That is oh so true,but looks like poop.gif Picture those BG with 4 to 6 inchjes of white with a solid black appearance.You tell me what looks better.Also, TLibby if you are getting 4 c-notes a job if installed the vinyl you probably would get 4 1/2 c-notes.Oh but what do you know you think Gary from Huper started F1.He worked for CP and was a Program Mgr.He did not develop the program.
tintmanlibby
QUOTE (maddtinter @ Nov 21 2008, 06:15 PM) [*]654127[/*]
either way he was a big piece of the puzzle ,i seriously dought i could get more money for vinal. i personally dont like it nor do i want to use it! eyebrows.gif .at any rate i don't need vinal, my skkt is uniform and laid down right no problem's here thumb.gif
i just cant let this vinal thing go
VIP tint + glass
for me its uniform down, or uniform not down. ANYTHING in between is a no go. you get "how come it looks good here then looks bad there?" and then youre just BSing till they go away
Monique
Never had a problem with those, just use vinyl. There's a black one I limo tinted and vinyled sitting on the Nissan dealers showroom floor with 350Z wheels and tires. Looks b*&%ing!
Contact: tintdude[a]gmail.com
