tintdude.com logo
isolate doors 2005 altima
watchdaride
On a 2005 nissan altima do you need to isolate each door for a trigger input or can you run it to the dome light ? NOt sure if it has that dome light feature ( like GM )where it sends a ground to check if the doors arent left open .
toodark
12 VOLT CONSTANT GREEN (+) IGNITION SWITCH HARNESS
STARTER BLACK/RED (+) See NOTE *1 IGNITION SWITCH HARNESS
STARTER 2 BLACK/YELLOW (+) See NOTE *1 IGNITION SWITCH HARNESS
IGNITION 1 BLACK/RED (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 RED (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 WHITE/BLUE (+) IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) RED/BLUE (+) IN DRIVERS SIDE KICK PANEL, HARNESS TO REAR OF VEHICLE
POWER LOCK BROWN (Negative (-)) See NOTE *2 IN PIN 45, @ BCM RIGHT OF FUSEBOX
POWER UNLOCK PINK (Negative (-)) See NOTE *2 IN PIN 46, @ BCM RIGHT OF FUSEBOX
DOOR TRIGGER See NOTE *3 @ BCM, RIGHT OF THE FUSEBOX
DOMELIGHT SUPERVISION LIGHT BLUE (-) @ BCM, RIGHT OF THE FUSEBOX, PIN 47
TRUNK RELEASE RED/BLACK (-) or BLUE/RED (-) IN PIN 30, @ BCM, RIGHT OF FUSEBOX
SLIDING POWER DOOR N/A
HORN GREEN/WHITE (-) @ STEERING COLUMN HANRESS
TACH ANY WIRE NOT RED,PINK,or BLACK @ ANY IGNITION COIL
WAIT TO START LIGHT N/A
BRAKE RED/GREEN (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM WHITE/BLUE (-) See NOTE *4 IN PIN 5, @ MODULE IN DRIVERS DOOR
ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY TRANSPONDER @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold. NOTE *2 TEST THESE WIRES WHILE TURNING KEY IN DRIVERS DOOR CYLINDER. NOTE *3 THE LEFT FRONT DOOR TRIGGER IS LIGHT BLUE(-) IN PIN 47. THE RIGHT FRONT DOOR TRIGGER IS PINK/BLUE(-) IN PIN 12. THE LEFT REAR DOOR TRIGGER IS RED/BLACK(-) IN PIN 48. THE RIGHT REAR DOOR TRIGGER IS RED/WHITE(-) IN PIN 13. WHEN CONNECTING TO AN ALARM SYSTEM, USE ALL 4 DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, SEE DIAGRAM NOTE *4 TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVERS DOOR KEY CYLINDER.
Isolate the doors.
CajunTinter
Here's what I have: BCM to right of fuse box
The LF door is lt. blue in pin 47, RF door is pink/blue in pin 12, LR door is red/black in pin 48, and RR door is red/white in pin 13. Use all four wires and diode isolate each.
Good luck !!!
watchdaride
QUOTE (CajunTinter @ Jan 12 2009, 07:29 PM) [*]661333[/*]
Good luck !!!
thanks
Contact: tintdude[a]gmail.com
