E60 touring rear door card removal?
Full Version: E60 touring rear door card removal?
Hi guys got a E60 touring booked in, i know lots of you guys leave the panals in place i do sometimes, but on this on im keen to pull the panal as the customers is a typical BMW owner! I cant seem to find any info on the fixings etc had a search? Anyone have info or a photo etc to pull the rear door cards, its a 2005/06 model. I take it the touring dosent have the issue of electronic boxes under the rear deck to be covered etc? Cheers Guys
Sorry guys to bump this up, anyone have any info or links to where i can find the fixings? Many thanks
You should be able to pull the top part of the panel away giving you enough access to remove the felt gasket.That is if you are only applying the tint.Grab the panel from below the small window and pull.Hope this helps.
