tintdude.com logo
99 Chrysler Sebring BG
GSRBOB
My first and hopefully last. I cant seem to shrink it as a one piece so i think im gonna just do a two piece. wall.gif
GSRBOB
Should i try the lift and pull technique?
Jeff Rutherford Jax fl.
looks like cheeco's work but are you dry shriniking baby powder works great
TTS
GSRBOB
Man i tried the 2nd time and still no luck. Im dry shrinking without babypowder. Just one H instead of a double H like i usually do.
obi wan folie
2piece it, if u do it right no one will see it ! my oppinion
Shady Sherlock
QUOTE (obi wan folie @ Feb 17 2009, 05:15 PM) [*]667446[/*]
I agree...
If I screw up a one piece more than once, I splice that biatch....
Got to get it done and get to the next thing, it's not worth the aggravation or the cost of wasted film.... grinning_and_saying_no.gif
OCC
that window shouldnt be giving you a problem fairly easy one, change your anchor line move it up a little more that way you take some of the stress off the top corners trust.gif
obi wan folie
QUOTE (Shady Sherlock @ Feb 18 2009, 01:18 AM) [*]667449[/*]
I agree...
same for me.... 2nd time messed up = 2piece da s$%t on tha bg!!!!!!!
GSRBOB
GSRBOB
If i change my anchor line i still have a hard time with the bottom. Even with the anchor line where its at now the bottom was given me hell at the corners.
Shady Sherlock
What film are you usin'??
GSRBOB
Im using llumar atc 35.
Shady Sherlock
biggthumpup.gif I have had problems on those in the corners too..
The lift/pull method will help a bit, but once that film stops shrinking it's done....
I'm sure you know that 1st hand.... I had an Eclipse kick me in the nutz a month or so ago...
I spliced it and I have to eyephuck it to remember where I spliced it at...
GSRBOB
I'm new to the lift and pull technique. This was my first attempt.
GSRBOB
I'm gonna try an seem it 2morrow but damn those defrost lines look pretty small.
lilDetails
if you vinyl the dots you will likely get it in one piece.......
Llumar ATR would go on that window but it was a barely done one for me.....
Now with Global HP I get those without much headache.....
GSRBOB
Ya I got it to the matrix but at about one inch away it stopped shrinking for me.
GSRBOB
From the top that is.
lilDetails
I would get a "craze" spot in the dot area.....would look like azz but would lay down and look good inside....usually would be about an inch from being all the way past the dots. The spot would look like crackled paint and be about 1 inch around.....
I could get the film to shrink past that mark but would get that mark on every one I did with Llumar....
If you are getting into the dot area then get some vinyl and cover the dots with it.....lick it, stick it, and send it on.
GSRBOB
Finished that biatch. I 2 pieced it.
Contact: tintdude[a]gmail.com
