tintdude.com logo
Best blade for vinyl cutters
pokeyz
Hi all,
New here, but have just purchased a Roland CAMM-1 plotter for cutting window tint. Does anyone have any advice on the angle of blade to use and any of the other settings for the plotter - force etc.
Also, I'm looking at the different software available. I'm in the UK and at the moment have only found Bekaert who supply ComputerCut. Does anyone know of any other UK based companies supplying window tint cutting software?
Cheers,
Tom
TINT
if im not mistaken i use the 45degree angle blade.
RoShute
(TINT @ Feb 18 2009, 02:33 PM) [*]667590[/*]
bingo.gif for most vinyl and films, unless they're thick like metallic vinyl or heat press vinyl and the such, then you need a 60 degree,unless you don't mind buying more blades from them getting dull.
dcurtisroland
(pokeyz @ Feb 18 2009, 09:36 AM) [*]667548[/*]
Hi all,
Cheers,
Tom
See if Roland UK supplies a 25 degree blade like we do here in the U.S. You can get by on a 45 degree blade, but a 25 will cut tint more consistently. A 60 degree blade should only be used for PPF.
-Dana
watchdaride
(dcurtisroland @ Feb 19 2009, 11:49 AM) [*]667806[/*]
Hi all,
Cheers,
Tom
-Dana
I use a 30' blade. Is there much of a difference between a 30' and a 25' ?
SPEEDFREAK
a little off topic but i cut a lot of small graphics has any one tried the 25 deg. blade on vinyl ?
and what blade offset is every one using ???
Contact: tintdude[a]gmail.com
