tintdude.com logo
Ford Focus 5 door 2005 reg (uk spec)
simons&cautostyle
Hi all,
Just a quick question ive got a Ford focus 5 door 2005 reg in on tuesday anything i need to know ? I have heard that taping the felt is best for a clean job but what tape does everone use ? Any advice would be great.
Thanks.
Shady Sherlock
simons&cautostyle
I wouldnt have thought they would be too much different did you tape the felt trims ? What tape do you use ?
Shady Sherlock
You mean tape them to prevent contamination??
If so, yes and with 1.5 inch painters tape..
I also give them a shot with compressed air to get the loose fibers out.
Do that before anything...
simons&cautostyle
Yeah thats what i meant to keep contamination to a minimum thats cool.I havent got compressed air but never mind il give them a good flush out then tape them.Thanks for the reply are the seals nice to slide behind or do you pull the panels ?
tintmor
tape them first or tape wont stick an give good flush just before instal.
simons&cautostyle
Ok i will do that lovely jubbly cheers for that il let you know how i get on should be cool.
Cheers
tintmor
real easy car u should have no problems
simons&cautostyle
Got the job done not to bad just a bit of a pain with the contamination from the seals but the customer was happy so its cool.
Cheers
Contact: tintdude[a]gmail.com
