tintdude.com logo
creasing
Full Version: creasing
Dj Kustoms
for awail i was using windowtintfacotry.com's nr charcoal film.when i was shrinking the bg i would always.literally always end up with a crease in the film.large fingers would turn into a crease.what could cause this........
TintDude
What shrink technique do you use and what film are you used to using instead of this one?
filmslayer
QUOTE (Dj Kustoms @ Mar 28 2009, 12:49 PM) [*]676923[/*]
lilDetails
don't shrink to the wrong sides of the film.....if you try to shrink the film the wrong way you will have this effect!
Dj Kustoms
actually its just this film because no other film has done this.sun gard doesnt for me.global wont.i use the bar of soap and micro fiber towell.
tint45
QUOTE (filmslayer @ Mar 28 2009, 12:00 PM) [*]676927[/*]
the tint pimp
QUOTE (tint45 @ Mar 28 2009, 01:44 PM) [*]676951[/*]
thatsnappyguy
if i were stuck using some thin films like that i would get creases too.
and yes lack of skill is most likely the problem...practice makes perfect..i creased alot when i was starting.i didnt really get it down till about 2 years in.
eric_64chev
Stick with 1.5 mil films. 1.0 mil film may seem cheaper but when you factor in scapping material from creasing it and shorter life, it's not worth messing with.
ClassOnGlass
too much heat too fast back off let the film shrink for itself dont force the shrink and keep it moving back and forth dont stay in one spot to long
Limo Tint Larry
Just to throw a lil DMC fun in there I can handle thin films without creasing... must be cause reps are always so good at tinting we have to stop and sell or else the world would implode from our mad tinting skills yo! spit.gif
Jarrett
QUOTE (Dj Kustoms @ Mar 28 2009, 10:49 AM) [*]676923[/*]
I went to windowtintfactory.com and I noticed that they dont sell "feet" of tint, but rather all their products are in "feets" of tint.
the tint pimp
QUOTE (Limo Tint Larry @ Mar 29 2009, 12:02 PM) [*]677055[/*]
Tint Artist
Dj Kustoms
ya actually very upset with the company.not gonna downgrade them but i got a crappy roll and they wnt return my calls refund me or nothing....gotten nowhere in a month
spyghost
from what i discovered, creasing is usually caused by overheating the finger or bubble
Limo Tint Larry
QUOTE (Dj Kustoms @ Mar 29 2009, 01:31 PM) [*]677142[/*]
That is weak, big or small there are a lot of companies out there who will handle your business professionally. Sucks to get burned, folks here usually speak the truth about who handles things in the tint biz well. beer.gif
FREDSTINTING
if it is a large finger you need to heat it up a little then push it down some and heat some more and then while its hot lick your finger so it will slide and push in the center of the finger to dived finger into two small finger if still to big dived them again . if you heat to much to fast you will always get creases. when shrinking big fingers
learn to dry shrink you shrink the whole film not just fingers
scottydosnntkno
QUOTE (Limo Tint Larry @ Mar 29 2009, 11:02 AM) [*]677055[/*]
QUOTE (FREDSTINTING @ Apr 28 2009, 09:07 PM) [*]683005[/*]
read around here before you post. he does dry shrink
shades of black
im pretty new to but i started practicing with GLOBAL HP. which is more like for pros cause i either burnt the film or creased it, its extra thick. then i switched to quick dry plus non reflective by global too and its been working excellent plus you can always contact HOWARD founder of global his customer service is great.
scottydosnntkno
QUOTE (shades of black @ May 15 2009, 01:05 AM) [*]686774[/*]
Jeff Rutherford Jax fl.
QUOTE (FREDSTINTING @ Apr 28 2009, 11:07 PM) [*]683005[/*]
newshade
Solarguard Supreme 40...super thin, creases very easily..warning. just put it on my windshield...*yeah I have a restricted license*. so its legal.
shaver
QUOTE (Dj Kustoms @ Mar 28 2009, 10:14 AM) [*]676932[/*]
Try using a cotton glove. You can control the film a little better. I couldn't imagine shrinking with a towel.
thatsnappyguy
QUOTE (newshade @ Jul 23 2009, 12:10 AM) [*]704933[/*]
Solarguard Supreme 40...super thin,,creases very easily..warning. just put it on my windsheild :}
not a smart thing to say around here.
ecrew16
I had the same problem with windowtintfactory.com's film. Too thin. Way cheap
twistedtinter
dont get in a hurry take ur time u will realize what ur doing wrong. shrink and break down big fingers.
twistedtinter
QUOTE (twistedtinter @ Aug 1 2009, 03:46 PM) [*]707007[/*]
before u use your hard card
Hondabuff
Start from the middle of glass and small strokes with the hard card. If you a greedy and try to shrink the film in a long swipe, thats when you will get your crease....gota be patient. Fingers on the edges of BG you have to work them back twards the middle of the glass. You can only shrink up and down to the direction of the factory edge. or the film your using is just poop.gif poop.gif poop.gif
pkj08
I bought tint from window tint factory and it also turns purple within a few months. This was the first tint I ever bought in bulk and I got comfortable using it , I had no idea it was so thin until I got new stuff from concord.
beano
i only ever wet shrink on side windows on very few vehicles that need it.
all rear windows i have done have been dry shrunk. very rarely do i stuff up on these. im mire likely to stuff an unshrunk side glass.
i use mr sheen spray wipe it off then use water down the outside edges. aplly the tint out side run across the horizontal from centre outwards both sides, then down vertical on the ends (H pattern) then use the heat gun up the "fingers" or "V`S" i call them to half the size or make two smaller ones.
keep reapeating it unti they are too small to halve then run the heat gun along until all the edges of the tint are sitting flush to the glass. doesnt matter so much if the centre areas are still wrinkly it gets pushed out lter with the squegee.
im not sure if anyone else uses this process but its what i learnt and what ive done the whole time ive been tinting
Sdtintdude
QUOTE (ecrew16 @ Aug 1 2009, 05:49 AM) [*]706951[/*]
i've had a few rolls from there too and its qualilty sucks. then i started buying from thetintstore.com and they are alittle better but still you had to buy the 1.5 mil that would last any length of time
Dj Kustoms
so a custy wanted a 12 inch strip on a s10..for the freaking life of me i cant get it done.last fingure it seems to crease.wtf is going on.i seriously dont get it...PLLLLLLLLLLLLLEAAAAAAAAAAAAAASE HELP
pkj08
QUOTE (Dj Kustoms @ Oct 6 2009, 09:40 PM) [*]721187[/*]
Sounds like your getting in a hurry. Just dont rush it.
Dj Kustoms
its just really irritating.i mean i consistantly waste film.
newshade
QUOTE (thatsnappyguy @ Jul 25 2009, 11:25 AM) [*]705588[/*]
Why ? Cause I have a restricted license and have to have it on my vehicle? lol2.gif
Dj Kustoms
nothing wrong with having windshield dark...aton of the people here have it.everyday coming out of school i see at leat 3 cars with dark windshields
pkj08
QUOTE (Dj Kustoms @ Oct 6 2009, 10:22 PM) [*]721199[/*]
been there know how you feel
Dj Kustoms
pk.........any advice.what should i do man?
pkj08
QUOTE (Dj Kustoms @ Oct 6 2009, 10:45 PM) [*]721217[/*]
The thing that helped me the most was just stay calm and dont force it. When you get frustrated it will never work. biggthumpup.gif
Dj Kustoms
thanks man.for some reason i just find strips on some cars the biggest pain.idk why
Contact: tintdude[a]gmail.com
