tintdude.com logo
renault 19 16v chamade (saloon)
fimmo
totally easy car,if your unsure,pop the panels as the rubber strip at the top of the door is a bit tight! rear window is by far the easiest 1 piece rear window i've done in a long time! watch how you tint the rear quarter tho,slightly over cut the diagonal side that goes down and cut it tight to the straight edge,if you cut it perfectly on the outside,when you put it on the inside there is a slight light gap!
nwflboy
Another Renault? Still hadn't seen one in years!
Contact: tintdude[a]gmail.com
