VAUXHALL astra mk 3/opel kadett mk3
Full Version: VAUXHALL astra mk 3/opel kadett mk3
watch this car!!! 3 door isnt too bad,bit off work but the 5 door is very hard! basically,like the new bug you have to shrink every window!!! dont know why vauxhall/opel made the windows as bad as they are,the felt covered rubber seals around the door are a nightmare, you have to remove it,it grips the glass so tightly your tint WILL NOT go between,remove it then wash down to remove all traces of the felt! hope this helps!
same as the vectra the seal is as tight as hell.
yeah, not had one of those in for a while thankfully, think theyve all been crushed!
with the vectra, just get youre cuts just right - not too much excess on each side, mask off the felt and bobs youre uncle!
