tintdude.com logo
using steam to apply PPF
TintWizard
was curious how many of you use steam to install ppf ?
TINTZEUS
I do sometimes. It really helps on some installs. It also helps to get the edges to lay down and seal really nice.
Shady Sherlock
obi wan folie
TintWizard
Just finished some ppf training..went well ! Using Clear Shield and steam went pretty good..good enough to bring a 1010 Mazda sport back to the dealer with a freebee of my training end result orngbiggrin.gif
Just need more cars to work on now ..someday I'll charge for it when I feel the work is consistant enough to put my name behind it Flaugh.gif
alberts316
I do and think it helps out big time no matter what film you use. It is a must for clearshield IMO. I give props to the guys that don't rely on them much. I always have my steamer going it seems like.
tint51
(alberts316 @ Mar 31 2009, 02:04 PM) [*]677578[/*]
I only use it sometimes.. to seems to sit down to quick.. I should ry it I guess,,,
tint_audiopros
when do you apply steam dunno.gif as your stretching the film or sealing edges , I've done my share of kits never needed a steamer though?
kikeb
what brand you guys used? Any particular brand? Any particular model or specification? I'm in San Juan, Puerto Rico and our wheather is always betweeen 75-90. Thanks
www.cuidamostucarro.com
GLASSPROTECT
Felixbiel
Never used a steamer when I first started doing them. Now I do, but only if the is big fingers or an edge I am having trouble. Works great and speeds up getting fings out.
TintJunkie
Damn it....now I have to go get one.
clearIT23
Never used steam ! Heard about it but have never felt the need been installing 4 years. What exactly do u use it for? I use bulk film and if a finger comes up i just wash it out with alcohol dont really have an edge problem my edges are wraped. y
watchdaride
(clearIT23 @ Apr 16 2009, 09:49 AM) [*]680729[/*]
I dont do PPF because the few kits i have done have all been off and always figured it would be better to put an over size then trim. Is that what bulk film instals are about ? . Do you have to cut all edges . Do you do bulk beacuse you dont have the plotter or do you prefer cutting it your self ?
clearIT23
Well one i dont have a plotter, havent had any luck with putting on kits. Kits just dont look good to me and dont think they cover enough. I prefer bulk film because its more custom of a job I take out emblems and grills and it just gives you a cleaner looking install.
tango2
Played with them found that you dont really need em TBH. They have their uses I guess but we work fine without them.
Cheers
tint_audiopros
the past few kits i've done really opened my eyes, now I understand what the steamer hype is all about ! I don't think i'll be paint filming without one thumb.gif
Bababooey
I use steamers to clean the all edges of the bumper. A ton of garbage gets in there that can fall under the film when you spray water on it. I've seen dirt streaming out from Mini emblems when blasted.
As far as using it on film, Xpel and Avery at least don't need it. They stretch so well as is. 3M I wouldn't even think of touching without one.
alberts316
(tint_audiopros @ Apr 20 2009, 01:23 AM) [*]681290[/*]
tango2
(Bababooey @ Apr 20 2009, 02:06 PM) [*]681312[/*]
I can see why peeps would want to use it on 3M but TBH once you get a feel for 3M (scotchgard) you can ditch on that, its biggest benefit I reckon is for fixing lift issues if you get any, it does a great job of getting dirt off the adhesive and 90% of the time you can lay it back down real well (especially with edge prep or pro bond) job done smile22.gif
Its other use is to get dirt out from around the headlamp apertures and other placs where crud can run out behind the film on install (will I need to post pics on that now ) smile22.gif
Cheers
Tom
Contact: tintdude[a]gmail.com
