tintdude.com logo
Got a Chrysler PT cruiser booked in morning
shadowline
Quick question whats the rear screen like had a look in the chrysler section, got a bit of info. Any secrets? Im using suntek carbon, standard 'H' ancor and a bit of lift and pull at the top i would guess? Thanks for any info guys
thatsnappyguy
lift and pull the top and bottom. its cake.
Tint Artist
QUOTE (shadowline @ Apr 15 2009, 09:10 AM) [*]680507[/*]
We have one to tint today! The back window isn't that bad but at the top you have to pull at the top by the little rubber nub that sticks out on the right side of the 3rd brake light! If you remove the panels you'll need a T25 for under the grab handle and a phillips for under the caps in the corners! The panels come off in under a minute when you find out where everything is and then pull the seal out!
WISEGUYSinc
hey pt losers are easy as f**k to tint! no need to pull any panels at all. the window roll up switches are on the dash and that sucks.. but overall breezy poop.gif box to tint! headbanging_to_the_music.gif
TintJunkie
Not the most difficult rear window to do, but its not for a novice either. I dont anchor the sides on them and I keep the film long on the top and bottom. Just anchor in the middle.
coolzone
On a PT cruiser I take panels off and remove brake light, wiper and washer. Everything disassembles in 5 minute. One horizontal anchor about half way up, maybe slightly higher and shrink away. I pull on the top around the corners. Shouldn't be too tough at all. Have fun with it and let everyone know what kind of cake it was.
shadowline
Well here she is finished.......
SunTek Carbon 5 shrank with a center anchor nothing on the sides, just taped down on each side, left long on the top to aid with a lift and pull where needed. Bottom left normal length, shrank it down first time no worries, pulled the panals as they come off in minutes. pleased all round as the car dealer turned up to collect and paid me in cash on the spot!
the tint pimp
Shady Sherlock
515tinter
wet shrink this one?
shadowline
QUOTE (515tinter @ Sep 10 2009, 01:18 AM) [*]715523[/*]
TTS
Contact: tintdude[a]gmail.com
