Newer Grand Prix
Mustangdroptop96
Apr 19 2009, 10:48 AM
Hey guys I have A newer grand prix GXP coming in later, couldnt find anything about them on here. Any tips, tricks? I usually dont pull out side seals i usually just tape them off, I just pull out the bottom sweeper, is it a pain on these? Back window problems? any input appreciated! Thanks guys!
Also, while your reading this, I have a Saturn Aura being dropped off tonight too, I couldnt find anything on those either. Anything on those I should be aware of? And how are they on the "cake" meter? They look pretty simple!
I just want to end on a note, is it just me or does anyone else hate GMs designs!! they make it near impossible to tuck tint on side windows on almost all their cars!
TTS
Apr 19 2009, 10:54 AM
the tint pimp
Apr 19 2009, 11:01 AM
scottydosnntkno
Apr 19 2009, 12:52 PM
QUOTE (Mustangdroptop96 @ Apr 19 2009, 10:48 AM) [*]681215[/*] Hey guys I have A newer grand prix GXP coming in later, couldnt find anything about them on here. Any tips, tricks? I usually dont pull out side seals i usually just tape them off, I just pull out the bottom sweeper, is it a pain on these? Back window problems? any input appreciated! Thanks guys!
I just want to end on a note, is it just me or does anyone else hate GMs designs!! they make it near impossible to tuck tint on side windows on almost all their cars!  Grand prixs are some of the easiest cars on the road to do. The BG is basically flat with nothing in the way, and the sides are small with well defined edges. Theres no need to pull the seals on any GM car, because their always nice and loose and the film slips right in. Maybe you were talking about "tucking" as in doing the top half then the bottom half? Even still theres no problems since all their windows have plastic side trim not felt, so you don't get contam. Should be a easy 1hr car. Same with the aura. Basically a mix between a GP/G6. Nothing hard about it at all.
TTS
Apr 19 2009, 01:24 PM
nctinter
Apr 19 2009, 01:38 PM
The Aura is pretty simple. Take the front rubbers off, they pull right out. I don't pull panels so don't know how to on this car, there is no need. Only real problem is the brakelight. You can get back there pretty good with a bulldozer or a green tailfin works the best. If you feel you can't get back there, the deck comes out easily. Fold the seats down there are 4 13mm bolts then the deck is held in with 2 push pins on either side. Oh the front doors and windshield are laminate so no razors. The rear doors have some felt so be careful on those
lilDetails
Apr 19 2009, 04:16 PM
on the Grand Prix pull the side/top seals off.....pop out like nothing and opens the window up like crazy....
scottydosnntkno
Apr 19 2009, 08:21 PM
QUOTE (nctinter @ Apr 19 2009, 02:38 PM) [*]681232[/*] The Aura is pretty simple. Take the front rubbers off, they pull right out. I don't pull panels so don't know how to on this car, there is no need. Only real problem is the brakelight. You can get back there pretty good with a bulldozer or a green tailfin works the best. If you feel you can't get back there, the deck comes out easily. Fold the seats down there are 4 13mm bolts then the deck is held in with 2 push pins on either side. Oh the front doors and windshield are laminate so no razors. The rear doors have some felt so be careful on those You can still razor the laminated glass. Do it all the time with no issues  QUOTE (lilDetails @ Apr 19 2009, 05:16 PM) [*]681244[/*] on the Grand Prix pull the side/top seals off.....pop out like nothing and opens the window up like crazy.... So their like the new impalas? It kinda looked the same, but I wasn't sure. Didn't want to mess around with it, but like the impalas its def worth the 20 seconds to pull it out
TTS
Apr 19 2009, 08:42 PM
The guy said in his original post that he doesn't want to pull the side seals....
scottydosnntkno
May 4 2009, 08:41 PM
QUOTE (TTS @ Apr 19 2009, 09:42 PM) [*]681280[/*] The guy said in his original post that he doesn't want to pull the side seals....  I normally don't like to either, but it takes all of 20 seconds to do all 4 on a impala, and he said these were similar so why not?
caprice305classic
May 5 2009, 08:41 AM
only problem i had was on the lower part of the bg is impossible with out the slammer or maybe the bulldozer, which ever one is the longer one. but sides are easy, and i didn't even need to pull any of the seals.
nctinter
May 5 2009, 08:47 AM
You can still razor laminated glass, but I scratched an RL window and an Aura window. So that was the end of that for me. Do what you want. No reason to use a razor on those cars. The Aura will scratch.
scottydosnntkno
May 5 2009, 09:07 AM
QUOTE (caprice305classic @ May 5 2009, 09:41 AM) [*]684417[/*] only problem i had was on the lower part of the bg is impossible with out the slammer or maybe the bulldozer, which ever one is the longer one. but sides are easy, and i didn't even need to pull any of the seals. The bulldozer is the longer one. a sideswiper will work too, or even a 12" white/black edge card.
scottydosnntkno
May 5 2009, 09:08 AM
QUOTE (nctinter @ May 5 2009, 09:47 AM) [*]684421[/*] You can still razor laminated glass, but I scratched an RL window and an Aura window. So that was the end of that for me. Do what you want. No reason to use a razor on those cars. The Aura will scratch. most newer cars(07+ ) I don't razor for the most part. I just use a scrubbie on them with no issues.
Monique
May 6 2009, 02:04 PM
QUOTE (scottydosnntkno @ May 5 2009, 09:08 AM) [*]684430[/*] QUOTE (nctinter @ May 5 2009, 09:47 AM) [*]684421[/*] You can still razor laminated glass, but I scratched an RL window and an Aura window. So that was the end of that for me. Do what you want. No reason to use a razor on those cars. The Aura will scratch. most newer cars(07+ ) I don't razor for the most part. I just use a scrubbie on them with no issues. I razor all rollups and never had a problem but then I don't do many domestic cars either. What kind of scrubbie do you use? I sometimes use the green/yellow but they've been known to scratch back glass, at least on Honda's. I still use 0000 steel wool on most cars but that stuff falls apart after a couple uses and can leave remnants in the side channels on roll ups.
scottydosnntkno
May 6 2009, 03:06 PM
QUOTE (Monique @ May 6 2009, 02:04 PM) [*]684815[/*] QUOTE (scottydosnntkno @ May 5 2009, 09:08 AM) [*]684430[/*] QUOTE (nctinter @ May 5 2009, 09:47 AM) [*]684421[/*] You can still razor laminated glass, but I scratched an RL window and an Aura window. So that was the end of that for me. Do what you want. No reason to use a razor on those cars. The Aura will scratch. most newer cars(07+ ) I don't razor for the most part. I just use a scrubbie on them with no issues. I razor all rollups and never had a problem but then I don't do many domestic cars either. What kind of scrubbie do you use? I sometimes use the green/yellow but they've been known to scratch back glass, at least on Honda's. I still use 0000 steel wool on most cars but that stuff falls apart after a couple uses and can leave remnants in the side channels on roll ups. I just use the standard white ones  no issues with scratching or anything. I would never use a yellow/green on any glass on a car ever
Contact: tintdude[a]gmail.com
