tintdude.com logo
Strange BMW 330 coupe problem...
ferris
Hi all
UK tinter here, been reading the forums for a while now (very helpful) and regret my first post is a problem. I tinted a 2008 BMW 330 coupe about 4 weeks ago with SunTek Carbon 35, the customer called the next day to say that when he used his rear de-froster his radio reception cut out then returned when the defrost was turned off. I advised that the tint would hold water for a couple of weeks and could be causing electrical interfearance with the antenna which is also on the back glass. Customer has just called today to inform that the problem is still present after 4 weeks. I removed the rear deck for the install, glued the matrix at the top and kept the water down to a minimum.
Has anyone encountered this problem or are there any suggestions about possible causes.... sounds like this could get expensive!!!
Thanks for any help.
naughtydog
I would disconnect the heated screen and retest. I think the aerial amp is in the NS c pillar, did you drop the side trims out?
I normally wrap the aerial amp before install if I pull out the deck - which is only on the odd one when I can make myself do that.
Other than that - it sound like you need a trip to the dealer...sorry stealer.
ferris
Side panels were out and water kept away from the black boxes.... There is a black box under the deck that I wrapped in plastic, the wire comming from it was slightly kinked, what is this box?
This is the first electrical problem I've ever had and it had to be on a BMW and we all know how understanding BMW owners are.
I feel a trip to the dealer comming on.
lorenzotint
Was the rear screen was tinted before?....I had a new 300C drive in for a premium install..... I had noticed very small amounts of defroster element gone. After I had showed the client the small defects on the rear screen he had confessed that another 12 volt shop had tinted it 2X before and that he was not pleased with there prodoct. So he told them to rip the klingon sh8t off. Go figure.....
ferris
First time install and all the elements look OK.... I've done a quick google search on defrosters interfearing with FM reception and it seems that many people suffer from this problem from new without tint (including quite a few BMW's). I spoke to the owner again and he can't recall ever using the radio and defrosters at the same time so cant be sure if the defect was there pre-tint so may be able to persue it as a warranty issue with BMW but I doubt it. Happy days.
JayZTint
QUOTE
That happened to me last week on a bg, check the defroster lines on them, could have already been there
Monique
QUOTE (ferris @ May 1 2009, 01:04 AM) [*]683448[/*]
Hi all
I had this exact problem after tinting a new Mitsubishi Eclipse at the dealer. The customer bought the car in the summer and didn't use the rear defroster until the rain came. When the defroster was turned on, radio reception went in the dumpster. I removed the tint and vinyl from the window and the problem persisted. The dealer replaced the rear window under warranty and it worked fine. So I tinted the back again and voila...no problem. Take from that what you will but there could be a problem with the glass/defroster element itself. One question...Did you cut on a defroster line?
TINT
always blame it on the tint guy!
good luck with everything mate!
OnTheDarkside
I say hey, if the car has warranty, plead ingorance and have the dealer fix their mistake on the vehicle they made....evilness I know broken.gif
TINT
QUOTE (OnTheDarkside @ May 2 2009, 12:29 AM) [*]683625[/*]
ferris
Thanks for your responses. No cuts on the BG inside at all... looks like this can be a problem straight out of the factory so I think i'm going to go down that route and see what happens. This is the first time in years that we've had a problem of any kind, who would have guessed it would be a BMW.
Tintim
QUOTE (Monique @ May 1 2009, 10:36 PM) [*]683615[/*]
Hi all
ditto on a lexus is new shape 18 months ago. It was the car not the tint.
matty cox
i had the identical situation on a 3 series touring.
naughtydog
mmm...maybe a little test before installation is advisable
tintec
a friend of mine has an m3 he had the exact same problem and the car never had tints,bmw replaced the rear screen under warranty,they said it was a common fault in coupes,its probably nout to do with the film or insatll at all
tintpro2007
I never take out rear decks to do an install... The only things i take out are brake lights.. Done many of these cars and never had any problems
Jeff Rutherford Jax fl.
is the antenna in the glass with the defrost on this car? good question
b7adh
QUOTE (naughtydog @ May 3 2009, 03:29 AM) [*]683782[/*]
its advisable to wark around the car with the customer aswell and point out any damages before any work is started, people always try it on
Monique
QUOTE (b7adh @ May 17 2009, 06:41 AM) [*]687182[/*]
I get that a lot but in the form of scratches in the glass. Unfortunately you can't see those until it's tinted, so I always get the blame. I've started pointing them out as soon as I start working on the affected glass, NOT waiting til I'm done.
jj
Done thousands of these Beemers and never had an issue like this, definatley a trip to the dealer and get them to fault find. More than likely a fault from factory..
Contact: tintdude[a]gmail.com
