2008 Escalade Glass Size
Full Version: 2008 Escalade Glass Size
How tall is the side glass on a 2008 escalade? I have a customer on weds. who wants all the factory gone over in 20, and wanted to see if a 20" would cover it? Or is it bigger like 22 or something.
20" is good. barely but good
20" works, you just have to line up the bottom to make it fit.
(KEDman @ May 3 2009, 07:41 PM) [*]683901[/*] 20" works, you just have to line up the bottom to make it fit. thats what I was hoping. My new film order should get here weds in the early afternoon, and I have this car in the morning. I have lots of 20" rolls, but barely any left on the 40"
See now that’s how a forum works you ask a question and you receive a reply. As most times it will be one that people can use. Nice to see you are taking advice.
(mikeMN @ May 3 2009, 09:07 PM) [*]683908[/*] See now that’s how a forum works you ask a question and you receive a reply. As most times it will be one that people can use. Nice to see you are taking advice. your the one who goes around picking apart what I say, and looking through old posts, not me (scottydosnntkno @ May 3 2009, 10:20 PM) [*]683915[/*] (mikeMN @ May 3 2009, 09:07 PM) [*]683908[/*] See now that’s how a forum works you ask a question and you receive a reply. As most times it will be one that people can use. Nice to see you are taking advice. your the one who goes around picking apart what I say, and looking through old posts, not me It is called ADDVICE YOU SHOULD TAKE IT. (mikeMN @ May 3 2009, 09:01 PM) [*]683929[/*] (scottydosnntkno @ May 3 2009, 10:20 PM) [*]683915[/*] (mikeMN @ May 3 2009, 09:07 PM) [*]683908[/*] See now that’s how a forum works you ask a question and you receive a reply. As most times it will be one that people can use. Nice to see you are taking advice. your the one who goes around picking apart what I say, and looking through old posts, not me It is called ADDVICE YOU SHOULD TAKE IT. everyone in this thread but you gave advice
im a panel puller and i drop em low. you can still line it up low just not too much. the small side of the rear door on the inside is different than the outside, so check it out b4 u cut. its also hella tight back there.
(scottydosnntkno @ May 3 2009, 11:10 PM) [*]683930[/*] (mikeMN @ May 3 2009, 09:01 PM) [*]683929[/*] (scottydosnntkno @ May 3 2009, 10:20 PM) [*]683915[/*] (mikeMN @ May 3 2009, 09:07 PM) [*]683908[/*] See now that’s how a forum works you ask a question and you receive a reply. As most times it will be one that people can use. Nice to see you are taking advice. your the one who goes around picking apart what I say, and looking through old posts, not me It is called ADDVICE YOU SHOULD TAKE IT. everyone in this thread but you gave advice I did give advice on this. It was on the way this site works. Not on you getting the last word or another post. And here’s a tip you should say THANK YOU to someone that gives you a right answer. (VIP tint + glass @ May 3 2009, 10:25 PM) [*]683968[/*] im a panel puller and i drop em low. you can still line it up low just not too much. the small side of the rear door on the inside is different than the outside, so check it out b4 u cut. its also hella tight back there. I'm a tucker so I usually just tuck in under just a tad. Thats why I like GM's with the loose seals, no worries. The small size of the rear is the back bottom corner right?
yeah. u got plenty of room on the bottom. u wont need to tuck the rubber at all.
once u see the car youll know what to look for. 20 fit the rear too just be careful lining up cuz the privacy is pretty dark (VIP tint + glass @ May 4 2009, 11:52 AM) [*]684061[/*] yeah. u got plenty of room on the bottom. u wont need to tuck the rubber at all. once u see the car youll know what to look for. 20 fit the rear too just be careful lining up cuz the privacy is pretty dark thats what I was figuring. I have a handheld fluorescent that I use for trimming the darker films on BG's that I was planning on using. I figured shrink wise it doesn't matter if your off a little bit, but cutting it would make more of a dif.
