tintdude.com logo
Small black cirlce thingy
Whiteboy623
I have a little problem I am trying to figure out how do I cut arround the SMall black circle things that the struts attach to on the b/g. Do i take them off maybe and if I do how do I do that?
scottydosnntkno
QUOTE (Whiteboy623 @ May 4 2009, 03:55 PM) [*]684157[/*]
what kind of vehicle are you doing? generally the struts come off, then you can unbolt the black mount and it will come out
Whiteboy623
Well its not a certain vehicle Ive seen them on a few different ones like Mitsu Suv's and the small pushout windows in the back on a F-250 exc just curiouse how to get arround those really close Smoker.gif
scottydosnntkno
QUOTE (Whiteboy623 @ May 4 2009, 04:04 PM) [*]684161[/*]
just look at them to see how to take them appart. usually theres a screw on the inside (f250s), or they unbolt after popping off the strut(old style escapes)
Drummmer69
Better off taking them out, I do alot of tractors and I always have to take the glass out, makes it much easier, no light gaps!! Might get a buddy to help, unless you have extremely long arms
scottydosnntkno
QUOTE (Drummmer69 @ May 5 2009, 07:48 AM) [*]684398[/*]
thats one thing I'm glad is not big on getting tinted around here is construction equipment. Just looking at them they look like a major PITA
filmslayer
if i'm not taking the glass out i use one of these ...
Drummmer69
I love doing tractors, The owners are great to deal with, they usually understand the time thing, especially the dirt issue, much more understanding than car owners. Easy money, no heavy shrinking, no bs!!!
arctint
QUOTE (Drummmer69 @ May 6 2009, 10:10 AM) [*]684730[/*]
How much do you charge on tractors? Do you charge by sq. ft. or by what tractor your doing? I've done a few and wanted to know what other people were charging.
Whiteboy623
ya ive been using that triangle thing but it leaves a gap and i am not satisfied with that. My problem was i tried to unscrew it from the inside but the little circle thing in the outside keeps turning and I am not sure what to use to keep it from turning.
Drummmer69
QUOTE
On average ---$ give or take, I have done a couple with cust. supplied tint (JANKY!) for ---$ no warranty.
I dont charge by sqft, or type, just wing it. Ive found to shoot the job high and explain the reason, having to dismantle the doors, bg, sg and so on. Farmers around here understand that...then when your done and it looks good, take off xx-xx$ and have a customer for life!
scottydosnntkno
QUOTE (Drummmer69 @ May 6 2009, 02:37 PM) [*]684822[/*]
QUOTE
bingo.gif take care of your customers, and you'll have them forever
cezztints
Soo how would u go about taking off the circle cus am haveing the same problem on this one car am doing mostly because the outside i used a coin but the inside has a washer in a different shape not round and space is totight to cut neaty inside soo really wanna know how to take those things off n i did pull off the first part but the circle i just cant get.. Please adview smile22.gif
scottydosnntkno
QUOTE (cezztints @ Aug 19 2009, 06:42 PM) [*]711451[/*]
it should have two flat spots for a open end wrench to fit over so you can unbolt it dunno.gif
HoLlYwOoD
to me taking off the lift arms is the easy part. The hard part is after cutting the circle when you go to put the arms back on and start turning the bolts. It will grab the tint and twist it all up. Ive tried heating the tint up and maybe drying it but still had no luck. The only thing I do is tell the custy to come back in a couple days once its dried and I'll put the lift supports back on. What do you guys do?
FREDSTINTING
all you have to do is use anything to give you the size circle as a guide depends on the size sometimes i use a dime or a quarter to follow. so you dont have to take off the hardware you make a cut from the edge of the film to the circle you cut out so the film splits in half there and you can get it around the inside window mount i only do this when the mount are on the right side of the window. some windows have 1 mount on the left side of the window and 2 on the right i take the screws out and and install the film and cut the holes out an then use your heat gun to heat up the film where the holes are so when you reinstall the the window putting the screws back into the mounts don't twist your film and screw up the installation
sunlimitedCT
VIP tint + glass
QUOTE
thats what i do but i start at around ---, then say "it wasnt as bad as i thought it would be, and i got it done pretty quick. so ill make it --- for you.
can we put prices on stuff like this?
Booms2Go
TintJunkie
QUOTE (FREDSTINTING @ Aug 20 2009, 07:16 AM) [*]711541[/*]
dunno.gif An entire paragraph with only 2 periods and no commas, and made no sense.
blade
Jeff Rutherford Jax fl.
QUOTE (filmslayer @ May 5 2009, 12:11 PM) [*]684433[/*]
if you dont want to buy one of these a socket set will work also....
Booms2Go
QUOTE (blade @ Aug 20 2009, 03:20 PM) [*]711672[/*]
TomTint
The only problem with pulling the latch off and filming behind the "black thingy" is that I am not 100% sure, when the BT goes back on and is tightened down, assuming you wait till its dry. I see cars like F250 F350 etc, rear 1/4 fingering from behind the BT a few yrs later. Sometimes, even though it does not look as good, a small ammount of daylight around a pivot point may not be a bad thing.
QUOTE (HoLlYwOoD @ Aug 20 2009, 12:53 AM) [*]711494[/*]
once you get it back on as you say you can run a blade around it releasing the preasure of those darn black round thingies
blade
how many times has TD mentioned not posting prices? more times than it's worth counting. now i'm gonna have to go through and edit all these posts so he doesn't go ballistic on your azzes. Flaugh.gif
QUOTE (blade @ Aug 20 2009, 03:43 PM) [*]711685[/*]
is there a place you send newbies so they know the rules?
Contact: tintdude[a]gmail.com
