Trying to Find a Fuse Location
Full Version: Trying to Find a Fuse Location
My 2001 Ford E-250 cargo van's cigarette lighter and auxillary 12 volt power isnt working and I want to check the fuse for it. The problem is the fuse cover is no where to be found and I cannot find the location of those fuse slots to check the fuse. I really dont want to pull every fuse in there to check it. If you dont know the location, how about the fuse amps (15, 20, 30????) Thankss Y'all!!!!! Oh and I already checked the service manuals...no diagrams to be found....
QUOTE (Cuttingedge @ May 5 2009, 06:00 AM) [*]684386[/*] My 2001 Ford Well there's your problem! Just kidding
Nevermind....After calling a few Ford Dealerships Parts and service departments without any luck, I found this link where you can download the owners Guides for every ford they make....Gee I cant believe the dealerships dont have this capability....
http://www.motorcraftservice.com/vdirs/ret...mp;menuIndex1=7 QUOTE (Cuttingedge @ May 5 2009, 09:00 AM) [*]684386[/*] My 2001 Ford E-250 cargo van's cigarette lighter and auxillary 12 volt power isnt working and I want to check the fuse for it. The problem is the fuse cover is no where to be found and I cannot find the location of those fuse slots to check the fuse. I really dont want to pull every fuse in there to check it. If you dont know the location, how about the fuse amps (15, 20, 30????) Thankss Y'all!!!!! Oh and I already checked the service manuals...no diagrams to be found.... take a test light ground it and then test the fuses to see which on doesn't light up the test light then pull it out and see if it blow some fuses will not show power unitl the switch is on and some will show power all the time you just need to know if your cig light and aux produced power when the car was on or you had to turn the switch on to find the fuse
Is everything else working on the van???? If so, Im gonna assume its not a fuse, normally cig lighter are fused with hazard lights, radio accessory, dome lights, or some other lower amp circut. But i have been wrong before, it was on a Thursday.
