tintdude.com logo
Eyebrow
Full Version: Eyebrow
Djkyle65
So i tired to do an eyebrow on my truck today (98 chevy silverado) and it seemed like the window had a large enough curve that it would not lay correctly do i just wet shrink it? Will it make the curve look stupid?
Thanks
scottydosnntkno
QUOTE (Djkyle65 @ May 7 2009, 05:29 PM) [*]685098[/*]
Thanks
usually I do a quick wet shrink on it. Maybe 10 little fingers that pop up, cut and slap it up.
TintJunkie
Screw that, lay it up, pull it tight and squegee. If fingers pops up, use a heat gun on the inside. Cake.
Tintskillz
There are some fingers on that one but I just lay it and use the hard card wrapped with a towel to take out the fingers. no heat.
HoLlYwOoD
bingo.gif no heat unless your doing a really wide strip
JBsTintshop
i just did about a 10 in brow on a 95 chevrolet today, piece of cake....no fingers, no shrinking, no heat. Not sure why everyone elses is fingering up. i never have trouble on any chevy's
HoLlYwOoD
yeah...some chevys rearview mirrors are so low you dont even need to cut around them. Piece of cake and money in the bank beer.gif
Sdtintdude
brow's are so eazy and quick extra money, most of the time they can be done in less than 15 min
mikeMN
What is the height of the windshield strip at the ends. you are attempting to apply?
thatsnappyguy
QUOTE (Sdtintdude @ Sep 6 2009, 08:19 PM) [*]714908[/*]
15 min's????? does you requir a 10 min nap while installing visors?
lilDetails
QUOTE (thatsnappyguy @ Sep 6 2009, 09:25 PM) [*]714919[/*]
so, Snappy....post up a video of you doing one. Measure, cut, or load plotter, cut, clean glass, and install then a final clean....I want to see 5 minutes!
Dj Kustoms
funny.i was gonna ask this q about brows..im having the same problem.i have to always shrink.and that doesnt work.i get huuuuuge fingers...someone should def post up a vid
Shady Sherlock
I usually always shrink them a little, it's kind of like snapping a door glass, just so I don't have to, mess with fingers inside, they tend to pop up and pull all that headliner junk down with them...
MobileTintInc
QUOTE (Shady Sherlock @ Sep 7 2009, 08:56 AM) [*]714954[/*]
Not a fan of the headliner junk myself. Pretty tough to clean the older trucks, bump your squeege on it an a pile of crust gets all over where you just cleaned. Usually on the 90s dodge trucks for me.
Sdtintdude
QUOTE (MobileTintInc @ Sep 7 2009, 07:05 AM) [*]714957[/*]
thats funny that you said that cause i did a legal brow for a customer on friday that had a 96 dodge truck, headliner was all dried up and it was horriable to keep clean and not get the crust of the headliner from getting on the film. but i did it legal, it may have been 3-4 in at the mirror and then tappered to 6" on the sides. i hate seeing brows out there where they are straight across, they look so gay but i see if they are wanting to keep it legal and as low as what they can get by with.
TintJunkie
QUOTE (lilDetails @ Sep 6 2009, 10:17 PM) [*]714927[/*]
I think it depends on the car. The ones with 2 as1 marks makes measuring fast and easy. I could certainly believe him if he was using a plotter. I hate doing eyebrows, but im not sure why. They are typically very easy, extra money, and we use whats left from a bg to do them in most cases.
FREDSTINTING
just spray your windsheild with your spary bottle and lay the film on it measure both sides equal not to pass the as1 markes and the cut and then slide the film down to he bottom of the matrix with out any light gaps and the heat shrink the finger out and then clean window on inside and peal liner and install film
there you have visor strip 101
Contact: tintdude[a]gmail.com
