Hi all,
I need to take the front door panels off on a vw transporter t5 van any ideas please ? Ive heard that the clips break is this true ?
Thanks
VW Transporter T5 front door panel removal ?
Full Version: VW Transporter T5 front door panel removal ?
Hi all,
I need to take the front door panels off on a vw transporter t5 van any ideas please ? Ive heard that the clips break is this true ? Thanks
Why dont you try and learn to leave the door panels in place - it saves a lot of headaches.
(naughtydog @ May 12 2009, 11:50 AM) [*]686036[/*] Why dont you try and learn to leave the door panels in place - it saves a lot of headaches. maybe hes doing speakers or other???
take off cover from handle and remove two t30 torx, 1 more torx in the lower centre of panel, pull the panel, clips dont often break, but dont need all of them to put the panel on anyway, overengineered as usual the vw's
well remembered coxy!
Nice one guys its a mates van and he didnt want all the clips broken !! So i thought id just ask better to be safe than sorry and i knew id get an answer from you guys cheers again.I do leave door panels on if possible but i just feel il get a better quality job doing it with them off on this one !! ( naughty dog ).Cheers.
I remove all panels, prefer it.... But its the way ive been taught!
T5's clips are quite hard core....
This is gonna sound a bit thick, but how do you get the handle cover off?
(PaulPaul @ Jun 4 2009, 07:12 PM) [*]692324[/*] This is gonna sound a bit thick, but how do you get the handle cover off? If you look underneath the handle cover you'll see 2 holes ( one left and one right) if you stick a small screwdriver in either hole...( this pushes the clips...) then pop he top left and top right of the handle cover... be carefull not to pull too hard or the clips break... there are really flimsy... but are not too tricky once you've removed a few... have the glue gun heated up just in case... (csignstints @ Dec 15 2009, 08:28 PM) [*]736779[/*] (PaulPaul @ Jun 4 2009, 07:12 PM) [*]692324[/*] This is gonna sound a bit thick, but how do you get the handle cover off? If you look underneath the handle cover you'll see 2 holes ( one left and one right) if you stick a small screwdriver in either hole...( this pushes the clips...) then pop he top left and top right of the handle cover... be carefull not to pull too hard or the clips break... there are really flimsy... but are not too tricky once you've removed a few... have the glue gun heated up just in case... i hope in the 6 months he was waiting for your reply he dosent loose the job!!!!!!
