tintdude.com logo
How to tell if it's gas
drmrjon
I have a cust on our local golf course that want entire house done and had his windows replaced aprox 3 yrs ago from lowes and can't remember if he purchased gas filled dual pane. Is there a way to tell if it is gas or not? I am out in so cal desert so I dont think I would be able to see if any water has got in or etc.. dunno.gif
Jeff Rutherford Jax fl.
i would think it would be stamped on the corner of the glass....all dual pain glass from my understanding are filled with gas. the way it was exsplained to me its not like filling a tire with air. they actual add beads inside the spacer that release the glass from the spacer into the inside of the pains...once its heated
would love to be corrected if im wrong? this how its was exsplained to me
vclimber
Home Depot?
3yrs ago?
scottydosnntkno
(vclimber @ May 14 2009, 07:50 AM) [*]686583[/*]
Home Depot?
3yrs ago?
Home Depot around here carries Pella and Hansons(A large local company) dunno.gif
drmrjon
He said he got them at Lowes and they were pella.
vclimber
There is a way to tell if they are leaking by detecting moisture with a little condensation trick and if that is there is moisture then the gas is gone.
Pellas are usually well-made so you are probably in good shape. Watch out for HD's Viking line. duck.gif
scottydosnntkno
(drmrjon @ May 14 2009, 04:21 PM) [*]686693[/*]
being pella they should be high quality. I'm surprised the custy wants to film them, every person I've ever met with pella won't do it since it voids the factory warranty.
mikeMN
(scottydosnntkno @ May 14 2009, 06:49 PM) [*]686705[/*]
scottydosnntkno
http://web.pella.com/products/Documents/Vinyl_Warranty.pdf
under restrictions. same reason my parents house isn't tinted since they have all new pella windows. I called the factory to confirm and they said that if you apply a film to their windows, it voids any glass breakage/seal/frame warranty. Talking to Joe my JWF rep he said the same thing Pella is the only company who restricts any film on their windows
mikeMN
(scottydosnntkno @ May 14 2009, 07:08 PM) [*]686715[/*]
vclimber
(scottydosnntkno @ May 14 2009, 05:08 PM) [*]686715[/*]
bs_flag.gif Your rep needs to do his homework other window MFG's restrict films among other common items and void their warranties.
Some film MFG's will provided term for term coverage if there is a written window warranty in force. I imagine JWF is not one of them, thus the reps comment. twocents.gif
pmuzik
(vclimber @ May 14 2009, 08:54 PM) [*]686725[/*]
bingo.gif I have yet to find a window MFG that doesn't void the warranty if film is applied. The application of film is only one of MANY things that will void a window warranty. I would guess that at least 25% or more of the estimates I go on have conditions that void the glass warranty. People are quite suprised when it's pointed out to them. I keep warranty info for all the window brands I come across so I can show them since most of the time they don't have the warranty information anyway.
I meant to include this in the original post Flaugh.gif it's an age thing
This is "Pellas" diclaimer with regards to Argon spit.gif just a VC said it probably isn't there anyway
Argon.
For Pella products labeled as having Low-E insulating glass with argon, Pella injects argon at the time of
manufacture. No warranty is made as to the amount or percentage of argon present in the insulating glass. It
is known that argon within insulating glass dissipates over time. The manner of use and conditions of
installation of the product will affect the rate of dissipation of argon out of the insulating glass. Pella makes
no warranty regarding the rate of dissipation of argon or the amount of argon remaining in the window at any
time after manufacture
film-R
darrin1
(vclimber @ May 14 2009, 04:54 PM) [*]686725[/*]
yep. we wouldn't be in business if we turned down ig units because of warranties. its not just pella.
drmrjon
I'm planning on using suntek IBDS 20%, do you all think it will be safe?
Fly Paper
Pella Pro line are really crap windows and that's what a lot of DIY suppliers sell. Almost every customer we sell film has Low-e of one kind or another so we give them matching Huper warranty
TTS
(drmrjon @ May 15 2009, 06:31 AM) [*]686790[/*]
According to their F2G chart if the windows are Low-E you are borderline....
Do you know the difference between Low-E coated windows and gas filled ?? dunno.gif
drmrjon
scottydosnntkno
(TTS @ May 15 2009, 03:47 PM) [*]686926[/*]
instead of the normal glass absorbing the long wave radiation, the low e coating reflects it back, similar to how tint acts which helps keep the glass from heating up, thus saving you on cooling costs.
TTS
(scottydosnntkno @ May 15 2009, 09:49 PM) [*]686969[/*]
I wasn't asking because I don't know... I was asking because I don't believe the original poster knows.... dipstick
vclimber
bs_flag.gif again. Low E does not save you on cooling costs. It reflects FIR back into the room saving you on heating costs.
Pit Stop
(vclimber @ May 15 2009, 10:00 PM) [*]686975[/*]
Im sure he googled it as usual, get your ammo ready for the dumbazzes response twocents.gif
scottydosnntkno
(TTS @ May 15 2009, 10:58 PM) [*]686973[/*]
I know you know, I was stating it for the OP's benefit
scottydosnntkno
(Pit Stop @ May 16 2009, 05:48 AM) [*]686993[/*]
I got it from wikipedia dunno.gif http://en.wikipedia.org/wiki/Low-e
reading it again I now see how it refers to also having a film applied to the outside pane to reduce the heat gain, and the low-e on the inside for heat loss
vclimber
(scottydosnntkno @ May 16 2009, 07:48 AM) [*]687035[/*]
You aren't benefiting anyone in this case, quit spreading false information. Verify before you post. twocents.gif
scottydosnntkno
(vclimber @ May 16 2009, 10:47 AM) [*]687059[/*]
Customtinting
How to tell if it's gas??? Hmm...............well, if scotty just passed through the room and ya smell something, it is probably gas.................... lol2.gif
mikeMN
(vclimber @ May 14 2009, 06:36 PM) [*]686701[/*]
What is this trick you speak of regarding detecting little condensation?
TTS
(mikeMN @ May 17 2009, 08:48 AM) [*]687195[/*]
I was wondering the same thing.... but I didn't figure I could pry it out of him.. Flaugh.gif
The first image that flashed in my mind involved ice... or maybe even dry ice on the glass to see if moisture 'condenses' on the glass between the panes....
I haven't worked it all out in my head yet... that was just the image that flashed by when I read that... beer.gif
drmrjon
Well, as for starting this post I still didn't get my answer. Thanks to those who tried to help me. whatjust.gif
I-tinted-the-pyramids
(drmrjon @ May 18 2009, 08:27 AM) [*]687354[/*]
Well as far as I remember oxygen is a gas and so is nitrogen. Umm air would be in a gas form just a bunch of different stuff.
''Dry air contains roughly (by volume) 78.08% nitrogen, 20.95% oxygen, 0.93% argon, 0.038% carbon dioxide, and trace amounts of other gases'' I googled it.
thus yes the space between two panes of glass has gas in it. IT IS NOT A VACUUM. Flaugh.gif Good luck!
(Jeff Rutherford Jax fl. @ May 18 2009, 12:57 PM) [*]687412[/*]
sux lazard that....it sux
(I-tinted-the-pyramids @ May 18 2009, 12:51 PM) [*]687407[/*]
go back and read again!
Jeff answered it on the 2nd post. I wasn't trying to take credit for it, went to lunch before I could point that out. icon_mrgreen.gif
TintDude
I've cleaned this thread up, let's try to stay on topic fellas.
filmslayer
and it was just starting to get fun...
drmrjon
You are correct, but there were no markings on the glass to indicate argon being there. I just can't take a chance on having anything break.
TTS
Maybe you should refer the job to someone who is familiar with flat glass work ???
mikeMN
(TintDude @ May 18 2009, 03:29 PM) [*]687463[/*]
What was your reason for the cleanup of this?As most topics do go off track
Contact: tintdude[a]gmail.com
