tintdude.com logo
Pulling 12 mil from box
Jack
From what I understand, it is much more time efficient to cut film on site. If this is true... how on earth does one cut 12 mil from the box????
vzla-tint
QUOTE (Jack @ Jun 15 2009, 05:05 PM) [*]695298[/*]
Not possible, need a film handler to do it on site... no short cuts with 12mil
FREDSTINTING
you don't pull it from the box you buy a film cutter that the film roll goes on and set the cutter blads to the measurement
of your window
set film cuter on top a 6ft ladders bolt it down on top step and it work beautifully
tint star
QUOTE (FREDSTINTING @ Jun 15 2009, 07:08 PM) [*]695311[/*]
of your window
set film cuter on top a 6ft laders bolt it down on top step and it work beautifully
bring super glue and duck tape, incase you cut yourself with that 12mil.
goog luck.
TintJunkie
Ive done 8mil out of the box many times...but 12mil? Couldnt imagine installing/cutting w/o a filmhandler. If you were to try to pull and cut from the box, the blade will wander every foot.
ClassOnGlass
screw on cutters i pull 12 mill right out the box 2 small pieces of abs one on each side of the box works fine
Jack
QUOTE (ClassOnGlass @ Jun 15 2009, 10:13 PM) [*]695357[/*]
Can you post pics?
yugo tinter
I did it once. Pulling 15 sqare meters is acceptible but more than that I couldnt handle.
VO|TRON
What are you guys talking about it cant be done? You guys must not have much experience with security film. I have cut 15mil out of the box and have done 100's of thousands of sq ft of 8mil outta the box. Also, you dont need a film handler to split film. A 4 inch scraper blade in the box with an aluminum channel works just fine as long as the blade is put in the box strait.
Almo
QUOTE (VO|TRON @ Jun 17 2009, 09:18 AM) [*]695642[/*]
I have to agree with you bud.
I too have pulled right up to 14 mil straight from the box (plus liner = 15 mil).
Simply take your time, pull steadily, and have your partner make the cut at the box end.
Good luck!
Almo
H.G.
More power to ya " cutting out of a box" , I'll stick with my film handler, make perfect cuts , cleaner installs and look professional at the same time.bananarock.gif
And }-----------> hang more film .
hoosierwindowtek
VO|TRON
just because u use the film handler doesnt mean you have cleaner installs and it also doesnt mean that you will install more sq. I have a film handler and use it to cut the film the day before the job. If I am cutting on site i just cut outta the box. It is faster cutting outta the box and I dont know how the film handler is more professional. And if you are not doing an attachment system then you will probably only get 1 maybe 2 sides especially if its tinted security film, cause frames are rarely perfectly strait.
LEO'n'DARTZ
mikeMN
I use a film handler for all except for 14mil as it has a 6” core and would cut that on a table to size at the shop. And if you ever use it the rolls are only 75ft and do not plan on using the last 44” or so as it will have embossed marks from core and will not look optically expectable to the customer.
mikeMN
QUOTE (LEO'n'DARTZ @ Jul 11 2009, 01:14 AM) [*]701874[/*]
FREDSTINTING
i always cut from a box never had a problem with it i done up 12ml film didn't have any problem just have to pay attention to what your doing . its called work. sure it's easyer to use a film cutter to do any film job but not necessary to use one .
davlisgen
It is really important to get that blade in strait. I stopped using 4" blades, and started using my super sharp hunting knife to cut 12mil. Works great , the nice thick blade doesn't move.
Contact: tintdude[a]gmail.com
