Got a 110 Wagon coming in next week...
Got awhole day to conquer the beast, but ideally want a rubber beading tool, to get the bead back in on the rear windows....
Where can i buy one from?
Thanx
Rubber Beading Insert Tool
Full Version: Rubber Beading Insert Tool
Got awhole day to conquer the beast, but ideally want a rubber beading tool, to get the bead back in on the rear windows.... Where can i buy one from? Thanx
Not sure - I did it with my thumbs once..they were hurting for friggin weeks after!
There on ebay if you look. think theres some mini specialist on there selling them, i got one if you get stuck
ITs all good...
FOund this lil puppy http://www.rejel.com/product/9528.aspx Nice and short, to avoid slippage! QUOTE (Solar-Shades @ Jun 29 2009, 01:50 PM) [*]698344[/*] Got a 110 Wagon coming in next week... Got awhole day to conquer the beast, but ideally want a rubber beading tool, to get the bead back in on the rear windows.... Where can i buy one from? Thanx Hey Solar, Done quite a few of these and that tool is a must have for Defenders - that said for the rear windows either side of the rear screen I would not take them out unless you have clear access. Make a very good template and fit them in situ. Reason being that they are so close to interior trim that you cannot get your hand in to re-fit the rubber without taking a load of car apart. You'll see what I mean if you get one with seats etc in the back - and it does not pop off as easily as the internal surround for that window. Good luck TT
I have this tool, covers almost all locking strip type gaskets.
Got mine from snap-on, makes it whole load easier. I always take out the windows either side of the rear screen although it does require the side panel (around the sliding windows) to be removed on newer vehicles - about 06-07 onwards i think...
only prob i came across once was when i removed the windows, i presumed the etching was on the outside of the glass and when i came to re fit them after tinting i found out that one glass had been replaced before at some stage with the wrong sided glass so the etching was on the inside on one side. had to retint it then.
QUOTE (b7adh @ Jul 1 2009, 08:17 PM) [*]698960[/*] only prob i came across once was when i removed the windows, i presumed the etching was on the outside of the glass and when i came to re fit them after tinting i found out that one glass had been replaced before at some stage with the wrong sided glass so the etching was on the inside on one side. had to retint it then. Thats how they are.. Same with the old Mini's QUOTE (Solar-Shades @ Jul 1 2009, 12:35 PM) [*]698966[/*] QUOTE (b7adh @ Jul 1 2009, 08:17 PM) [*]698960[/*] only prob i came across once was when i removed the windows, i presumed the etching was on the outside of the glass and when i came to re fit them after tinting i found out that one glass had been replaced before at some stage with the wrong sided glass so the etching was on the inside on one side. had to retint it then. Thats how they are.. Same with the old Mini's bloody defenders, there's me thinking it had been replaced.
OMG....
Make that 3 110's next week... I swear some lil buggers on a 110 defender forum, saying "hahaha we have found a sucker to tint our tractors...".... Coming from far and wide, hay bales en all!..
Poor guy
3hours, 46min...
Start to finish, That was from Workshop Door Down to Workshop Door Up! Perfect job too..... ;-) QUOTE (Solar-Shades @ Jul 7 2009, 12:09 PM) [*]700716[/*] 3hours, 46min... Start to finish, That was from Workshop Door Down to Workshop Door Up! Perfect job too..... ;-) How did you do the sliders? Did you take them out? did you remove the seats in the rear shithouse area?
just curious, do you guys tint all of the glass on the sliders (tuck it right under the seal) or cut it to the seal and leave a strip of the glass untinted
Tom well done any pictures mate ??
do remember doing a defender & prayed it was my last, a right old pos Filthy inside and nearly new. Admittedly didnt have a lock strip tool for the beads back then thankfully had none since, :> there is a god lol. QUOTE (naughtydog @ Jul 7 2009, 07:23 PM) [*]700718[/*] QUOTE (Solar-Shades @ Jul 7 2009, 12:09 PM) [*]700716[/*] 3hours, 46min... Start to finish, That was from Workshop Door Down to Workshop Door Up! Perfect job too..... ;-) How did you do the sliders? Did you take them out? did you remove the seats in the rear shithouse area? Took the sliders out..., and the seats in the %&$# house, I left in, I cleaned fook outta them, got old olfa in there, cleaned, sprayed, and took a thin slice off, gave it some heat so it was more giving, linted, and slid the bugger in, looked perfect, was supprised with the outcome... ;-) QUOTE (pulsar2000 @ Jul 7 2009, 11:57 PM) [*]700797[/*] Tom well done any pictures mate ?? do remember doing a defender & prayed it was my last, a right old pos Filthy inside and nearly new. Admittedly didnt have a lock strip tool for the beads back then thankfully had none since, :> there is a god lol. No Pictures, I need to start taking pics, cos ive done some nice motors recently.... QUOTE (Solar-Shades @ Jul 9 2009, 09:42 AM) [*]701300[/*] QUOTE (naughtydog @ Jul 7 2009, 07:23 PM) [*]700718[/*] QUOTE (Solar-Shades @ Jul 7 2009, 12:09 PM) [*]700716[/*] 3hours, 46min... Start to finish, That was from Workshop Door Down to Workshop Door Up! Perfect job too..... ;-) How did you do the sliders? Did you take them out? did you remove the seats in the rear shithouse area? whats the crack with removing the sliders? do you have to drill all the riverst out or what? Please tell me more Tom? Linted? - whats that? Took the sliders out..., and the seats in the %&$# house, I left in, I cleaned fook outta them, got old olfa in there, cleaned, sprayed, and took a thin slice off, gave it some heat so it was more giving, linted, and slid the bugger in, looked perfect, was supprised with the outcome... ;-) QUOTE (pulsar2000 @ Jul 7 2009, 11:57 PM) [*]700797[/*] Tom well done any pictures mate ?? do remember doing a defender & prayed it was my last, a right old pos Filthy inside and nearly new. Admittedly didnt have a lock strip tool for the beads back then thankfully had none since, :> there is a god lol. No Pictures, I need to start taking pics, cos ive done some nice motors recently....
whats the crack with removing the sliders? You dont have too, but its a million times easier, and a billion x's cleaner, and you get a job which is 110%
do you have to drill all the riverst out or what? Yeah, drill out the rivets, and then re rivet back in, gotta be carefull not to scratch the paint work, time, and a steady hand is the key for these puppies Please tell me more Tom? Linted? - whats that? Paper towel.... ;) Pentagon term... QUOTE (Solar-Shades @ Jul 9 2009, 01:42 PM) [*]701379[/*] whats the crack with removing the sliders? You dont have too, but its a million times easier, and a billion x's cleaner, and you get a job which is 110% do you have to drill all the riverst out or what? Yeah, drill out the rivets, and then re rivet back in, gotta be carefull not to scratch the paint work, time, and a steady hand is the key for these puppies Please tell me more Tom? Linted? - whats that? Paper towel.... ;) Pentagon term... Do the rivets need painting again afterwards?
Nope, Rubber covers them lil bad boys!
so the cover flicks off nd you just replace the rivet?
do you just knock the old rivet into the body after drilling the head off? QUOTE (Solar-Shades @ Jul 3 2009, 08:33 PM) [*]699555[/*] OMG.... Make that 3 110's next week... I swear some lil buggers on a 110 defender forum, saying "hahaha we have found a sucker to tint our tractors...".... Coming from far and wide, hay bales en all!.. I will gladly refer them all onto you
i may have one at the end of this week, i'll post pics up if i do it. not looking forward to it but the cash is just as green as the rest
Another 1 for me 2mrw!
