tintdude.com logo
anyone have a problem with audi a5 amp
ClassOnGlass
one of my guys did a a5 on sat the customer states there is no sound now he brought it to the dealer and they said the tinter blew out the amp.....amp is in the quater panel dealer said $1700 to fix
thatsnappyguy
well its the same song with the bmw's. wrap it up.
ClassOnGlass
i did 3 no issues my other guy did 2 no prior problems ??????
nctinter
We have covered this problem. You need to wrap those bitches up. Well on the S5 anyway. Not sure on the A5. Tinters having been killing those things and yeah they are not cheap
thatsnappyguy
i fried the bmw amp which is in the rear 1/4 panel also. all the higher end cars that come in, i always check in the trunk just to make sure b4 i start slappin.
Shady Sherlock
QUOTE (ClassOnGlass @ Jul 14 2009, 07:47 PM) [*]702978[/*]
You got luck then....
He probably used more water than you did...
I always check for them b4 too...
watchdaride
QUOTE (ClassOnGlass @ Jul 14 2009, 08:42 PM) [*]702975[/*]
$1700 for a car amp. That must be damn good amp.
sunlimitedCT
I did the same thing, you have to wrap it up. I got the audi dealer to knock it down to 1200 though....
sunlimitedCT
Just found out they also have a water sensor in the doors, should that get too wet, the window will drop and shatter...Thats a $700 part
ClassOnGlass
wtf are you shitting me
Shady Sherlock
QUOTE (sunlimitedCT @ Jul 16 2009, 08:37 AM) [*]703319[/*]
That doesn't make any sense to me....
What if they have the window down and it rains or something, just doesn't sound right.... dunno.gif
jttint1
yep,i do manny at the audi dealer,i wrap the amp in the trunk.thats the only one i know bout.should have ripped the tint off let dry for couple days then bring car to dealer.payin for it or put thru insurance?
sunlimitedCT
QUOTE (Shady Sherlock @ Jul 16 2009, 09:41 PM) [*]703496[/*]
Apparently it's a safety thing, you drive into a lake or something the windows drop and let you get out...
Shady Sherlock
QUOTE (sunlimitedCT @ Jul 17 2009, 05:56 AM) [*]703577[/*]
Johnnytint
QUOTE (ClassOnGlass @ Jul 14 2009, 10:42 PM) [*]702975[/*]
Sorry to hear of your misery Joe but that %&$# is old news. You cant be soaking down that rear window (5 gallon sprayer i bet). put a towel over the amp and when your done see if it gets wet. I use a hand sprayer and there isnt a drop of water on the towel when im done, some guys see a wet towel afterwards.
tip #2 i had a guy cover the amp but there must have still been water puddled up on the metal under the rear deck. first time the guy stepped on the gas the water poured right in the amp.
Audi put out a bulletin on this issue back in Oct No warranty on water damaged amps!
ps i saw the car at Atl Audi we all had a good laugh at your expense
call me so i laugh at you in person 478-7544
Booms2Go
QUOTE (sunlimitedCT @ Jul 17 2009, 08:56 AM) [*]703577[/*]
Contact: tintdude[a]gmail.com
