tintdude.com logo
Anybody use these?
Full Version: Anybody use these?
shaver
http://www.zoladist.com/p-27-micro-edge-tr...wn-windows.aspx
Hope it's not a repost...probably is. How do they work?
darrin1
the outer edge hangs over the top edge of a rolldown. blade is held in the unit and sits on the film and slides across the top edge to even up a jacked up cut.
PJF
QUOTE (shaver @ Jul 21 2009, 08:03 PM) [*]704622[/*]
These tools do exactly as stated above. They were very popular about 5-7 years ago, but they do not sell in large quantities any longer. If you have been tinting for awhile, you will likely never use it. Not that expensive though if you wanted to give it a try.
Shady Sherlock
Flaugh.gif I have one, but I never ended up using it......
GabesWindowTinting
Straight blade and a slow steady hand, and you'll never need this.
running free
QUOTE (GabesWindowTinting @ Jul 21 2009, 10:54 PM) [*]704649[/*]
TTS
Booms2Go
QUOTE (darrin1 @ Jul 21 2009, 08:07 PM) [*]704623[/*]
mikeMN
sunlimitedCT
QUOTE (mikeMN @ Jul 22 2009, 08:22 AM) [*]704693[/*]
PJF
QUOTE (sunlimitedCT @ Jul 22 2009, 10:07 AM) [*]704707[/*]
This tool could be used for a couple of things. The primary design of the tool was to run the longer edge across the top of a roll down window and the inserted blade would cut a 1/8" microedge at the top of the window. Most experienced tinters have learned to have excess film hanging over the top edge and just run their knife along the top edge to make that cuts. Then you just bump the film down 1/16"-1/8" to make your microedge. Some people could actually use it to fix a small area of jagged edge of an already cut microedge, but that was not the reason the tool was created. As I mentioned, most tinters that have been installing for awhile would never use this tool, but many starting installers like it because you can get a decent microedge from using it.
Maybe this should be a tool that I do one of the demo videos on the zoladist.com website.
blade
those things are worthless Flaugh.gif it's geared towards a newbie who can't cut patterns but you need to be an experienced film handler to be able to use it properly. Flaugh.gif
sunlimitedCT
I think you'd only end up jacking up the corners of the film where that gadget couldn't reach anyway..
PJF
QUOTE (blade @ Jul 22 2009, 11:04 AM) [*]704740[/*]
I actually agree quite a bit with this statement. They are geared for a newbie, but are still not easy to use properly. You tend to figure out how to use it properly when you get more experience, and by then you no longer need it. I guess the reason all the tools suppliers still carry it, Zola Distributing included, is because it has always been a tool that people seemed to want.
mikeMN
PJF
QUOTE (mikeMN @ Jul 22 2009, 12:38 PM) [*]704754[/*]
clear max
QUOTE (running free @ Jul 21 2009, 08:22 PM) [*]704655[/*]
mikeMN
QUOTE (PJF @ Jul 22 2009, 11:51 AM) [*]704757[/*]
I will tell you this it has to do with the angle of the blade I will leave the rest up to you.
darrin1
QUOTE (mikeMN @ Jul 22 2009, 12:53 PM) [*]704783[/*]
talking about angling the blade somehow to make the gap smaller or to cut better?
PJF
QUOTE (mikeMN @ Jul 22 2009, 03:53 PM) [*]704783[/*]
mikeMN
QUOTE (PJF @ Jul 22 2009, 07:39 PM) [*]704875[/*]
mikeMN
QUOTE (darrin1 @ Jul 22 2009, 05:53 PM) [*]704841[/*]
cut better and ........
tintgod
I myself wouldn't waste 11 buck on that thing...if you cant get a straight edge cutting along the top of the window..you shouldn't be tinting...period...but what do i know. Flaugh.gif
mikeMN
QUOTE (tintgod @ Jul 22 2009, 09:23 PM) [*]704892[/*]
tintgod
QUOTE (mikeMN @ Jul 22 2009, 10:30 PM) [*]704894[/*]
darrin1
QUOTE (mikeMN @ Jul 22 2009, 06:30 PM) [*]704894[/*]
I've used it for that, but a metal straightedge is faster for me if the length isn't too long.
shaver
I figured it was something like that. I have no problems cutting straight edges...so I won't be buying on! Thanks for the input guys.
Contact: tintdude[a]gmail.com
