tintdude.com logo
Pissed!!!!
Full Version: Pissed!!!!
cmotown1
HELP!!! I took my 2003 Buick Park Ave to get the windows tinted and I really wasn't satisfied. The windows had contamination and air pockets everywhere. I took it back to have him fix the problems, but it seems as though he can't handle the back window for some reason. Here are some pics of my rear window after being parked out in the 80+ degree sun for two days. Let me know what you think. I will be taking it back again.
Heres what my rear corner window looks like:
thatsnappyguy
looks like he didnt use steal wool on the back window to knock down the fat defroster lines. that is what causes the big air line on the top and bottom of each line. it almost looks as if he did use steal wool in some spots but not other. if he did use it, he was consistant with it all the way across. the 3rd and last picture is that happens when the installer used heat to make the film stick. that will look better as the days goes by, but not completely go away. the 4th pic is some of the tape line left behind from the temp tag that was in the back window at one point.
basically the installer didnt take his time in prepping the glass properly b4 installation. it doesnt look like theres much dirt in the window, so he did do a clean job, but he should have spent a lil more time inspecting the glass, and scrubbing then lines with the steal wool.
i sometimes spend 20 minutes just in the back seat of a car just cleaning and making sure the the film will lay down properly. its all about perparation to get the proper outcome.
the tint pimp
QUOTE (thatsnappyguy @ Jul 23 2009, 11:34 AM) [*]705052[/*]
micro-edge
Sure it could be better than what it is, but i've seen much worse...Steel wool would've definately helped on those lines.
blade
thick defrosters are thick defrosters. dunno.gif steel wool would help a little but now that it's dried well, just run your thumb over them to lay them down more. all the other crap is reason enough for it to be redone though.
cmotown1
I'm also pissed about the clear line that I see in my back window from the inside. Its like he tried to put two pieces of tint together, but they didn't lineup.
thatsnappyguy
i really cant make out what the is in this pic. it looks like more of a scratch that a seam. if it is a seam, you have gone to the wrong shop. a pro should be able to do every back window in one peice. there mat be 2 exceptions, but your car is not one of them. this is an easy, small back glass. 2 piecing is not an option.
cmotown1
Thats the sunlight that I see when looking out the back window.
blade
you need to quit yelling in your posts. a normal size non-bold font works just fine. yelling isn't gonna get your back window fixed. Flaugh.gif
cmotown1
QUOTE (blade @ Jul 23 2009, 12:27 PM) [*]705120[/*]
Didn't know that was consider yelling here. Most forums consider yelling all CAPS!
Booms2Go
thatsnappyguy
well, that seam in the middle is good enough reason to bring it back and get it done again, but chances are that he wont be able to do that, if i could, he would have.
this looks like the work of beginner, or a hack.
blade
QUOTE (cmotown1 @ Jul 23 2009, 12:30 PM) [*]705121[/*]
TINTZEUS
From what I can see.....the tinter was in the battlezone. The car had tint on it befor. This was a R&R ( remove and replace )
In some of thoes pictures, what you are seeing is old adhesive. Old adhesive from the old tint.
Looks to me like the tinter worked on that backglass , to get the fingers off the defrosters.
Mr paladin
thatsnappyguy
QUOTE (TINTZEUS @ Jul 23 2009, 03:58 PM) [*]705196[/*]
obviously he used heat on the edges, but its hard to tell if it was tinted, it the glue is from the temp tag or old film. the way its shredded into a straight line, looks just tape shreds with the grain.
TINTZEUS
QUOTE (thatsnappyguy @ Jul 23 2009, 02:26 PM) [*]705228[/*]
It is an 03. It was tinted befor and maybe removed befor trade in. For sure adhesive on the glass. I think your right Snappy....looks like temp tag tape ... mad3.gif
Either way whoever tinted this car............looks to me like they did not prep the glass.
thatsnappyguy
i got an idea, lets try to guess what kind of film it is. i say its johnson SP 5%.
Limo Tint Larry
Just curious, how much did you pay for this work? Did the shop seem somewhat professional?
lilDetails
Dude, it's an 03 Buick. I have done a fair share of those and can tell you that those defrosters will look like that. I clean with steel wool and still have that. The one pic is a bad end to the seam line. I don't know why anyone would need to 2 piece that window, but some do what they have to do.
The contamination "line" looks like an old sticker or something that was missed. How clean is the car OVERALL?
Anyway....if you aren't happy then go complain again. Did they redo the window once? Or just blow you off?
The defroster lines will lay down a bit better when they are totally dry. Believe it or not, but you might still have some moisture in there that will hold the film....just give it some more time and press it out with your finger....
thatsnappyguy
QUOTE (lilDetails @ Jul 23 2009, 04:54 PM) [*]705240[/*]
well why done my lines ever look like that? i have done a bunch of these cars, and the first few did look like this, but i realized what it was and never looked like that again. im sorry, but i havent been tinting that long compared to alot of the guys here, and i know im not the best, but the way i look at it is if i see a job that i know i can and have done better, that job is not acceptible.
TINTZEUS
I think the tinter cut the film along the defroster, to get the fingers to lay down. It's not a 2peece.
thatsnappyguy
QUOTE (TINTZEUS @ Jul 23 2009, 05:00 PM) [*]705242[/*]
he probably had a bad "peanut" problem on them fat ass lines.
tuttle
did u get a 1yr. warrenty with that
cmotown1
QUOTE (Limo Tint Larry @ Jul 23 2009, 02:38 PM) [*]705234[/*]
They run a mobile glass service, but they do the tint out of their 2 car garage.
QUOTE (thatsnappyguy @ Jul 23 2009, 02:34 PM) [*]705233[/*]
Yeah your right about the tint. How could you tell??
Booms2Go
cmotown1
$170
TTS
Booms2Go
QUOTE (cmotown1 @ Jul 23 2009, 06:35 PM) [*]705257[/*]
$170
cmotown1
QUOTE (tuttle @ Jul 23 2009, 03:24 PM) [*]705248[/*]
I'll just take it back next week again.
QUOTE (Booms2Go @ Jul 23 2009, 03:34 PM) [*]705256[/*]
Seattle, WA
cmotown1
sunlimitedCT
Booms2Go
sunlimitedCT
cmotown1
QUOTE (sunlimitedCT @ Jul 23 2009, 04:17 PM) [*]705286[/*]
Sorry to bust your bubble, but these are the real ones.
sunlimitedCT
I do stand corrected..... beer.gif I didn't think they dated back to 03.....whats even worse is people are still buying those
Booms2Go
cmotown1
QUOTE (sunlimitedCT @ Jul 23 2009, 04:28 PM) [*]705296[/*]
People are still buying what??
Booms2Go
They got them sticky thangs that look just like your original vents.... thumb.gif
TTS
QUOTE (cmotown1 @ Jul 23 2009, 03:41 PM) [*]705267[/*]
Booms2Go
QUOTE (TTS @ Jul 23 2009, 07:44 PM) [*]705311[/*]
cmotown1
QUOTE (TTS @ Jul 23 2009, 04:44 PM) [*]705311[/*]
No, just too lazy to take them down. Lol!!!
blade
you payed $170 in seattle? you went to the wrong shop then.
cmotown1
QUOTE (blade @ Jul 23 2009, 04:58 PM) [*]705325[/*]
Yeah, I'm starting to see that.
thatsnappyguy
QUOTE (cmotown1 @ Jul 23 2009, 04:34 PM) [*]705255[/*]
i can spot that tint from a mile away.
cmotown1
QUOTE (thatsnappyguy @ Jul 23 2009, 09:45 PM) [*]705361[/*]
Is that not one of the quality tints??
Limo Tint Larry
one slick tinter
QUOTE (blade @ Jul 23 2009, 08:58 PM) [*]705325[/*]
I was gonna ask: "When did Blade start dropping his prices??" spit.gif poking_someone_in_the_eye.gif
blade
QUOTE (one slick tinter @ Jul 24 2009, 04:30 AM) [*]705388[/*]
Contact: tintdude[a]gmail.com
