hi just curious what color does every one use to make a flesh color for faces and hands ??
Jeff
Doing a face on a decal what color do you use ?
Full Version: Doing a face on a decal what color do you use ?
Jeff
Wow open question as this depends on the type of person you are trying to simulate. You should contact www.solargraphics.com and get the film sample booklet.
this is in 100% vinyl I'm doing a calvin and need to do it in full color
QUOTE (mcpcola @ Aug 4 2009, 02:23 PM) [*]707741[/*] http://www.signwarehouse.com/VOR6411510-p-...1-1510-023.html or maybe http://www.signwarehouse.com/VOR6411510-p-...1-1510-082.html thats what i thought i should use, any one ever air brush on the vinyl ?? QUOTE (SPEEDFREAK @ Aug 6 2009, 04:17 AM) [*]708146[/*] QUOTE (mcpcola @ Aug 4 2009, 02:23 PM) [*]707741[/*] http://www.signwarehouse.com/VOR6411510-p-...1-1510-023.html or maybe http://www.signwarehouse.com/VOR6411510-p-...1-1510-082.html thats what i thought i should use, any one ever air brush on the vinyl ?? yep.
I do airbrush and yes you can do vinyl just fine. What paint are you using?
i was just going to ask what paint does every one use ????
Jeff
That's a wide open loaded question. What are you doing with it. Is it going to be inside or outside? Do you have a paint booth or are you planning to spray in an open shop area?
QUOTE (mcpcola @ Aug 7 2009, 01:05 PM) [*]708547[/*] That's a wide open loaded question. What are you doing with it. Is it going to be inside or outside? Do you have a paint booth or are you planning to spray in an open shop area? open area in a different room than the shop so over spray and fumes would not be a problem. i do paint work out there now. outside decals for the most part been dong a lot of automotive type stuff but some inside stuff also.I I want to try dong the air brushing to add to my skill level and also be able to do some really custom work Jeff
PM sent.
thank you
Y don't you get it printed on vinyl?
QUOTE (toodark @ Aug 9 2009, 10:45 AM) [*]708980[/*] Y don't you get it printed on vinyl? Don't have $30,000 for the printer to do the vinyl
