My peel board.
Full Version: My peel board.
Had a couple people ask about my portable peel board. Used a 33"x40" storm door insert and used 1/2" self adhesive pipe isulation from Home Depot. Painted one side white so when your cutting, it is easier to see. Best part is just lean it up against the car in the area your working at. Tad low to the ground if you have bad knees but havent had any issues. You can flip it up onto your garbage can and use it as a cutting table also. Really minimizes the time that the adhesive is exposed with a glass wall.
Thats cool hondabuff...good idea.....
Inventive!
Not sure about leaning anything aginst a customers car tho..
Not sure about doing mobile either...I don't....but it is a good idea!
What ?? Your kind of a tint gypsy aren't you ???
I go to one place on saturdays...already have a peel board set up, and I'm inside....not exactly mobile......
Do you transport tools and/or material ???? Do you do it MOBILE ??
mobile as in you can move it around the garage. Gota watch out for the crusty cars when you lean it up against them.
QUOTE (Hondabuff @ Aug 10 2009, 03:32 PM) [*]709242[/*] Had a couple people ask about my portable peel board. Used a 33"x40" storm door insert and used 1/2" self adhesive pipe isulation from Home Depot. Painted one side white so when your cutting, it is easier to see. Best part is just lean it up against the car in the area your working at. Tad low to the ground if you have bad knees but havent had any issues. You can flip it up onto your garbage can and use it as a cutting table also. Really minimizes the time that the adhesive is exposed with a glass wall. ![]() ![]() QUOTE (TTS @ Aug 10 2009, 06:47 PM) [*]709257[/*] Do you transport tools ...... Yes...If that makes Me mobile....so be it....
