Huper Optik C40 or ESC 45?
Speed_Of_Flight
Aug 14 2009, 09:24 AM
Hey Guys... New to the forum...Not in the business but got burnt up pretty bad with a recent Suntek ULVDS 40 install gone awry.  404 square feet....51 panes. Having said that...Hired a new IWFA certified contractor and am trying to decide between ESC45 or the Ceramic 40. Being quoted the same for either film and since the C40 is a double layer-do you guys recommend that over the ESC45? Is thicker better with HO? Durability is an issue.
Oh...I've Simonton double pane Low E Argon filled windows. Thanks for your expertise in answering this newb question. Regards...Greg
vclimber
Aug 14 2009, 09:36 AM
QUOTE (Speed_Of_Flight @ Aug 14 2009, 09:24 AM) [*]710009[/*] Hey Guys... New to the forum...Not in the business but got burnt up pretty bad with a recent Suntek ULVDS 40 install gone awry.  404 square feet....51 panes. Having said that...Hired a new IWFA certified contractor and am trying to decide between ESC45 or the Ceramic 40. Being quoted the same for either film and since the C40 is a double layer-do you guys recommend that over the ESC45? Is thicker better with HO? Durability is an issue.
Oh...I've Simonton double pane Low E Argon filled windows. Thanks for your expertise in answering this newb question. Regards...Greg  Sorry about the bad experience Greg. Ceramic 40 will be a lot less reflective than the ESC 45. ESC is a Huper Ceramic Film it is the single ply version which is more reflective. HO ceramic is super durable... the ceramic has been tried and tested in industry for decades, inert material that will not corrode, contains no dyes, and has a lifetime residential and 15 yr commercial warranty. We sell a lot of C-40 and I'd go with that because of the lower reflectivity.
Speed_Of_Flight
Aug 14 2009, 10:10 AM
Thanks..VC!!
The HO rep told me that the reflectance was a "moot point" due to the reflectivity of the low E glass...Something about the ESC 45 being only a per cent or two higher.
I think either film would/will be fantastic-JC what film costs more as I think the C40 is 2x as thick(~) as the ESC45...
Since I am paying the same for either film..should I go with the C40? Oh....The Suntek ULDVS 40's reflectivity was 14 and C40 is 9.
Sorry to be repetitive-I'm only learning now as a result of having a second company come in and strip 400 sq off and put the HO back on.
This is where all the smart dudes are...so I come humbly and thankful for any advice I can receive.
Regards...Greg
P.S. Long to short...Is C40 more costly that ESC45-per square?
micro-edge
Aug 14 2009, 10:21 AM
I don't know much on huper, but i'd go with V's advice since he's so big on huper he would know which is better. Im just curious what happened on the suntek? Was it looks or installation gone bad or what?
vclimber
Aug 14 2009, 10:26 AM
QUOTE (Speed_Of_Flight @ Aug 14 2009, 10:10 AM) [*]710022[/*] Thanks..VC!!
Regards...Greg
P.S. Long to short...Is C40 more costly that ESC45-per square? You said that the installing company bid both at the same price. I was just saying that C-40 typically costs a little more but without seeing the job I can't really comment much on price. Yes, the low E makes exterior reflectance a moot point but interior reflectance will be less with the C-40. That is important at night.
Speed_Of_Flight
Aug 14 2009, 10:50 AM
C40 it is...Thanks VC and Micro! The Suntek install was a complete fiasco. Windows were not cleaned/prepped; gaskets were cut off all windows; many windows were cut without perimeter gaps, multiple doors have clouded up; getting bubbling on several windows already; squeegee must have had a burr....17 windows have scratches on them. Seems as though, after reading Sunteks SOP for installation that half the steps required were skipped...VC's quote is very applicable... The bitterness of poor quality lingers long after the cheap price is forgotten.The guy was a new Suntek dealer so I got the ULVDS 40 done at a 5 per square-that should have set flags and buzzers off. I got what I paid for. Thanks so much for your advice guys-C40 it is! Regards...Greg
Speed_Of_Flight
Aug 14 2009, 10:52 AM
Oh...VC....XLNT point on the Interior reflectance!
Thanks again...Greg
micro-edge
Aug 14 2009, 10:56 AM
QUOTE (Speed_Of_Flight @ Aug 14 2009, 01:50 PM) [*]710035[/*] C40 it is...Thanks VC and Micro! The Suntek install was a complete fiasco. Windows were not cleaned/prepped; gaskets were cut off all windows; many windows were cut without perimeter gaps, multiple doors have clouded up; getting bubbling on several windows already; squeegee must have had a burr....17 windows have scratches on them. Seems as though, after reading Sunteks SOP for installation that half the steps required were skipped...VC's quote is very applicable... The bitterness of poor quality lingers long after the cheap price is forgotten.The guy was a new Suntek dealer so I got the ULVDS 40 done at a 5 per square-that should have set flags and buzzers off. I got what I paid for. Thanks so much for your advice guys-C40 it is! Regards...Greg  Sorry for your misfortune, sounds like you mainly had a bad installer...I like the ultravison so far, hopefully it holds up (better than VC claims that it will  )...
vclimber
QUOTE (Speed_Of_Flight @ Aug 14 2009, 10:50 AM) [*]710035[/*] C40 it is...Thanks VC and Micro! The Suntek install was a complete fiasco. Windows were not cleaned/prepped; gaskets were cut off all windows; many windows were cut without perimeter gaps, multiple doors have clouded up; getting bubbling on several windows already; squeegee must have had a burr....17 windows have scratches on them. Seems as though, after reading Sunteks SOP for installation that half the steps required were skipped...VC's quote is very applicable... The bitterness of poor quality lingers long after the cheap price is forgotten.The guy was a new Suntek dealer so I got the ULVDS 40 done at a xx per square-that should have set flags and buzzers off. I got what I paid for. Thanks so much for your advice guys-C40 it is! Regards...Greg  That is an inherent problem with our industry. A lot of time the film is not at fault, it is the company that installs or rather, try to install it at discount prices which makes them have to rush the job and then problems ensue... Hey, make sure they fix your gaskets. I'm not sure how much they cut off but you need some gasket to hold your glass in.
film-R
Aug 14 2009, 11:56 AM
I like the ESC and use it a lot as a lot of people seem to like the extra privacy the ESC provides and the little extra heat rejection. I'll tell you that ESC35 and 45 you can see out at night with out an issue. That being said, C40 is easier to see out and in by a little and is more in cost then ESC45. C40 is an amazing film, its crazy but the C50 which is lighter, you cannot tell its any darker tehn the window not filmed next to it, but the VIEW is ENHANCED significantly !! C-40 is the same. If it were my choice, I would only base my decision on if you want a little added daytime privacy, if that's not a concern, go for the C40
Roach
Aug 14 2009, 09:57 PM
Greg, any chance you could drop me an email? I want to ask you something off-forum.
Thanks!!!
RoAcH
roach@azclan.net
tintgod
Aug 15 2009, 05:51 AM
so there was nothing wrong with the film...just the install?
and to correct you...the reflectivity of the ultra 40 is 10 interior and 11 exterior..the SOLAR reflectance is 14
tint_audiopros
Aug 15 2009, 03:46 PM
maybe its just me but I like the UV 40 its a nice looking film and great to work with.
tintgod
Aug 15 2009, 04:54 PM
why would you put one yrs experience if you are not in the business? I am thinking this thread was a set up  ..kinda weird he would call Vclimber..VC in his second post..
Speed_Of_Flight
Aug 15 2009, 05:04 PM
TG... It twas you that put me up to it..Did you forget already? I'm a spy from the IWFA... LOL...Paranoia will destroy ya..... Regards....Greg
Booms2Go
Aug 15 2009, 05:11 PM
And He calls TintGod TG........
sunlimitedCT
Aug 15 2009, 05:22 PM
and knows the iwfa
tint star
Aug 15 2009, 05:32 PM
speed, r u greg m from old m tint?
tintgod
Aug 15 2009, 06:06 PM
QUOTE (Speed_Of_Flight @ Aug 15 2009, 08:04 PM) [*]710298[/*] TG... It twas you that put me up to it..Did you forget already? I'm a spy from the IWFA... LOL...Paranoia will destroy ya..... Regards....Greg  paranoia...haha...you wish...you just got caught...
Speed_Of_Flight
Aug 15 2009, 06:09 PM
Caught doing what....
I stated my situation quite clearly-not sure why you must inject some ulterior motive.
Regards...Greg
Speed_Of_Flight
Aug 15 2009, 06:12 PM
"knows the iwfa"
Yes...my installer(Huper Optic) is IWFA certified.
And the film is NFRC certified. Wow..I got educated after I got burned. God forbid a client knows a few acronyms.
And I'm from the IRS cause you guys are using this forum as a cover for a huge "kind bud" selling biz.
LOL...You guys R 2 funny.
Greg
sunlimitedCT
Aug 15 2009, 07:20 PM
How'd you klnow about the KB
Booms2Go
Aug 16 2009, 02:38 AM
QUOTE (sunlimitedCT @ Aug 15 2009, 10:20 PM) [*]710332[/*] How'd you klnow about the KB
mikeMN
Aug 16 2009, 04:29 AM
QUOTE (Speed_Of_Flight @ Aug 15 2009, 08:09 PM) [*]710322[/*] Caught doing what....
Regards...Greg Are you on any other sites like this??
vclimber
Aug 16 2009, 09:46 AM
QUOTE (tintgod @ Aug 15 2009, 04:54 PM) [*]710291[/*] why would you put one yrs experience if you are not in the business? I am thinking this thread was a set up  ..kinda weird he would call Vclimber..VC in his second post..  Well if it was a set up it sure attracted you like a bug to a light.
Booms2Go
Aug 16 2009, 09:49 AM
QUOTE (vclimber @ Aug 16 2009, 12:46 PM) [*]710407[/*] Truth be told the irony is just getting started...
tintgod
Aug 16 2009, 10:37 AM
QUOTE (Booms2Go @ Aug 16 2009, 12:49 PM) [*]710411[/*] QUOTE (vclimber @ Aug 16 2009, 12:46 PM) [*]710407[/*] Truth be told the irony is just getting started...   haha..got it before the edit...
vclimber
Aug 16 2009, 10:54 AM
QUOTE (tintgod @ Aug 16 2009, 10:37 AM) [*]710421[/*] QUOTE (Booms2Go @ Aug 16 2009, 12:49 PM) [*]710411[/*] QUOTE (vclimber @ Aug 16 2009, 12:46 PM) [*]710407[/*] Truth be told the irony is just getting started...   haha..got it before the edit...  But do you get?
TintDude
Aug 16 2009, 11:10 AM
The IP is legitimate, no matches with any other members, so back on topic.
mikeMN
Aug 16 2009, 12:27 PM
QUOTE (vclimber @ Aug 16 2009, 12:54 PM) [*]710425[/*] QUOTE (tintgod @ Aug 16 2009, 10:37 AM) [*]710421[/*] QUOTE (Booms2Go @ Aug 16 2009, 12:49 PM) [*]710411[/*] QUOTE (vclimber @ Aug 16 2009, 12:46 PM) [*]710407[/*] Truth be told the irony is just getting started...   haha..got it before the edit...  But do you get?
tintgod
Aug 16 2009, 12:59 PM
QUOTE (TintDude @ Aug 16 2009, 02:10 PM) [*]710426[/*] The IP is legitimate, no matches with any other members, so back on topic. you know as well as me.. there are ways around that..
TintDude
Aug 16 2009, 01:09 PM
Not sure I understand what the motivation would be, but OK.
tintgod
Aug 16 2009, 01:55 PM
QUOTE (TintDude @ Aug 16 2009, 04:09 PM) [*]710435[/*] Not sure I understand what the motivation would be, but OK. ok..ill leave it alone.
vclimber
Aug 16 2009, 08:08 PM
QUOTE (tintgod @ Aug 16 2009, 12:59 PM) [*]710434[/*] QUOTE (TintDude @ Aug 16 2009, 02:10 PM) [*]710426[/*] The IP is legitimate, no matches with any other members, so back on topic. you know as well as me.. there are ways around that..  Yeah, and we all know that between you, me, and SOF only one of us has had multiple accounts on TD.com in the past. Take the conspiracy theory elsewhere, I was just helping someone with a question what's the crime in doing that? QUOTE (tintgod @ Aug 16 2009, 01:55 PM) [*]710442[/*] QUOTE (TintDude @ Aug 16 2009, 04:09 PM) [*]710435[/*] Not sure I understand what the motivation would be, but OK. ok..ill leave it alone.  Your argument never held any water to begin with thanks for doing us all a favor here.
tintgod
Aug 17 2009, 07:09 AM
i take it others cant leave it alone and continue to whine about things.
Contact: tintdude[a]gmail.com
