Varibend PCM-BEND is an easy and cost-effective semi-automatic metal channel letter processing equipment and with wide applicability. Its use-function is not inferior, and has a very good processing extensions function which makes operators attain a greater space to improve the processing capacity expansion. It is good at processing surround of channel letter and applicable at LED channel letter、stainless steel letter, iron letter, aluminum letter, acrylic plastic channel letter and luminous resin channel letter, has extraordinary ability to control accuracy can be limited at 0.01mm, can meet harsh and complex technology accuracy needs of a variety copulate inlaid levels.
