#1 By "Hondabuff"
Portable Peeling Board
QUOTE
Had a couple people ask about my portable peel board. Used a 33"x40" storm door insert and used 1/2" self adhesive pipe isulation from Home Depot. Painted one side white so when your cutting, it is easier to see. Best part is just lean it up against the car in the area your working at. Tad low to the ground if you have bad knees but havent had any issues. You can flip it up onto your garbage can and use it as a cutting table also. Really minimizes the time that the adhesive is exposed with a glass wall.
#2 By "spyghost"
Final glass wiping technique
QUOTE
hi,
just sharing a very simple tip as the final wiping technique in glasses.
use two microfibers during the final wiping technique and always wipe in one direction for a particular side.
e.g. wipe the outisde of the glass horizontally and the inside vertically. in short, always do perpendicular wipes relative to the inside or outside.
why?
this allows you to determine which side you need to do some more cleaning/wiping
