anyone have experience cutting templates for Ford Truck sliders.. 3 piece. 5%....Need any tips..
Should I trim the rubber in the inside after i Cutout the shape??
Ford Truck 3-piece Sliders
Full Version: Ford Truck 3-piece Sliders
always found them to be kinda hard, usually A LOT of dirt in the older ones...cut on the outside, trim film on the inside at the top
(APTINT @ Aug 28 2009, 11:15 AM) [*]713209[/*] always found them to be kinda hard, usually A LOT of dirt in the older ones...cut on the outside, trim film on the inside at the top k, sounds like a plan.. I've done with a com.cut templte before but they were still not that great..
I cut the outer pieces on the outside of the truck a little bigger, trim on the inside w/o peeling liner, and cut the 2 inner pieces on the inside of p/u gives a much cleaner edge. good luck with the dirt!!! Scrub with a white scrubbie, scrub again...still getting dirt on ptowel, scrub again. Run your knife along the gaskets seperating them a little easier. when appling tint dont spray window, instead spray the hell outta the film.
(Drummmer69 @ Aug 28 2009, 02:48 PM) [*]713250[/*] I cut the outer pieces on the outside of the truck a little bigger, trim on the inside w/o peeling liner, and cut the 2 inner pieces on the inside of p/u gives a much cleaner edge. good luck with the dirt!!! Scrub with a white scrubbie, scrub again...still getting dirt on ptowel, scrub again. Run your knife along the gaskets seperating them a little easier. when appling tint dont spray window, instead spray the hell outta the film. Great tips thanks a lot.. someday i will be this great....! (tint51 @ Aug 28 2009, 01:11 PM) [*]713196[/*] anyone have experience cutting templates for Ford Truck sliders.. 3 piece. 5%....Need any tips.. Should I trim the rubber in the inside after i Cutout the shape?? I ALWAYS CUT THE CENTER OF THE SLIDING FROM THE INSIDE AND AND THE 2 BIG TRIANGLE LOOKING WINDOWS FROM THE OUTSIDE AND CUT IT REAL TIGHT (tint51 @ Aug 28 2009, 01:11 PM) [*]713196[/*] anyone have experience cutting templates for Ford Truck sliders.. 3 piece. 5%....Need any tips.. Should I trim the rubber in the inside after i Cutout the shape?? If it's a new one you can't trim the inside...Its all plastic instead of rubber (Drummmer69 @ Aug 28 2009, 02:48 PM) [*]713250[/*] I cut the outer pieces on the outside of the truck a little bigger, trim on the inside w/o peeling liner, and cut the 2 inner pieces on the inside of p/u gives a much cleaner edge. good luck with the dirt!!! Scrub with a white scrubbie, scrub again...still getting dirt on ptowel, scrub again. Run your knife along the gaskets seperating them a little easier. when appling tint dont spray window, instead spray the hell outta the film. (FREDSTINTING @ Aug 28 2009, 05:18 PM) [*]713275[/*] (tint51 @ Aug 28 2009, 01:11 PM) [*]713196[/*] anyone have experience cutting templates for Ford Truck sliders.. 3 piece. 5%....Need any tips.. Should I trim the rubber in the inside after i Cutout the shape?? I ALWAYS CUT THE CENTER OF THE SLIDING FROM THE INSIDE AND AND THE 2 BIG TRIANGLE LOOKING WINDOWS FROM THE OUTSIDE AND CUT IT REAL TIGHT i was thinking that would work that way to cut first.. Thanks. (FREDSTINTING @ Aug 28 2009, 05:18 PM) [*]713275[/*] (tint51 @ Aug 28 2009, 01:11 PM) [*]713196[/*] anyone have experience cutting templates for Ford Truck sliders.. 3 piece. 5%....Need any tips.. Should I trim the rubber in the inside after i Cutout the shape?? I ALWAYS CUT THE CENTER OF THE SLIDING FROM THE INSIDE AND AND THE 2 BIG TRIANGLE LOOKING WINDOWS FROM THE OUTSIDE AND CUT IT REAL TIGHT i was thinking that would work that way to cut first.. Thanks. (tint51 @ Aug 28 2009, 01:11 PM) [*]713196[/*] anyone have experience cutting templates for Ford Truck sliders.. 3 piece. 5%....Need any tips.. Should I trim the rubber in the inside after i Cutout the shape?? dude all u need to do is cut the shape outside close and then trim the gasket on the inside. its hard but,it looks way better that way. and good luck w/the dirt.
Pull it out and take it apart. That's how I've always done them.no gaps no dirt
(VIP tint + glass @ Sep 18 2009, 09:39 AM) [*]717155[/*] Pull it out and take it apart. That's how I've always done them.no gaps no dirt done that my share of times...here in Hawaii those square head screws get rusty real fast.. (sunlimitedCT @ Aug 29 2009, 02:05 AM) [*]713311[/*] (tint51 @ Aug 28 2009, 01:11 PM) [*]713196[/*] anyone have experience cutting templates for Ford Truck sliders.. 3 piece. 5%....Need any tips.. Should I trim the rubber in the inside after i Cutout the shape?? If it's a new one you can't trim the inside...Its all plastic instead of rubber If its a new one its glued in with borders. and if power slider better yet. (gramma @ Sep 18 2009, 11:18 PM) [*]717270[/*] (VIP tint + glass @ Sep 18 2009, 09:39 AM) [*]717155[/*] Pull it out and take it apart. That's how I've always done them.no gaps no dirt done that my share of times...here in Hawaii those square head screws get rusty real fast.. yeah if the lower ones are rusty we take a drill to them. you dont need to put another screw in there cuz the the threads will be pokin out a 1/4" and it will line up with the whole in the track. the top ones always unscrew out
