tintdude.com logo
Best way to clean glass
Select One
Hello to all tinters world wide,
what is the best way to clean automotive glass and what type of lint free cloth/paper, squeegee(s) are used? Below is the process I use and still seem to have small particles of contamination......
1) Spray glass with Johnsons solution and scrub the glass
2) Shave and squeegee the glass
3) Spray and squeegee
4) Clean with slightly damp lint free paper
5) Clean with dry lint free paper
6) Wet the glass and apply film.
What other processes are tinters using?
Thanks,
Select One
TTS
Do a search.. there is a list of cleaning techniques floating around here.. beer.gif
Booms2Go
There not using paper towels one step before applying the film! No wonder You have contamination!
Wet
Scrape
Wipe TOP edge and side channels of window with paper towel
Wet
Squeegee
Wet
Apply film
Select One
Im using lint free paper it is not your average paper towel.... You've put "wipe top edge and side channels of window with paper towel" What type of paper towel are you using Booms2Go?
QUOTE (Booms2Go @ Sep 16 2009, 11:37 PM) [*]716742[/*]
Wet
Scrape
Wet
Squeegee
Wet
Apply film
Booms2Go
Select One
Thanks Booms2Go, we'll give it a go. What squeegee do you use to clean the glass? We use the Unger pro handle with black squeegee blade.
Thanks,
Select One
scottydosnntkno
QUOTE (Select One @ Sep 16 2009, 04:56 PM) [*]716752[/*]
Thanks,
Select One
That squeegee is more intended for FG use since its not that flexible. Pick up a black smoothie squeegee, the one with the grey tube on top. Then cut one since into an angle. Its the same material as what you have, just bigger and works a lot better for auto.
I spray and scrape the window, wrap a microfiber around a plat. ez reach and wipe that down the left side channel of the window to get all that crap out. Then use the black smoothie to squeegee the window dry from left to right. Then, using a clean part of the microfiber do the right side and bottom gasket the same was as the left. The microfibers pick up a lot more dirt than a paper towel does, and is a lot tougher and doesn't break appart and leave pieces.
Then spray and install(right away after for me, I do everything else before cleaning, then clean and install)
tint14u
QUOTE (Booms2Go @ Sep 16 2009, 06:37 PM) [*]716742[/*]
Wet
Scrape
Wet
Squeegee
Wet
Apply film
you hit that dead on the head
b7adh
even though it says "lint free" they always can leave shite behind. just do a final squeegee with a yellow turbo or something similar before you apply or as booms says above
Contact: tintdude[a]gmail.com
