Sprayed On Tint On The Outside
Full Version: Sprayed On Tint On The Outside
Anyone have advice (besides just breaking the glass) on how to remove thirty year old sprayed on tint?
bag/soak with ammonia, then scrape with NEW razor blades, starting in a small area to make sure you aren't scratching the glass with the blades.
QUOTE (TintDude @ Sep 23 2009, 03:24 PM) [*]718274[/*] bag/soak with ammonia, then scrape with NEW razor blades, starting in a small area to make sure you aren't scratching the glass with the blades.
lots of water and baby shampoo and stainless steel blades.. makes it way easier than any other product.. and is cheap
QUOTE (Jeff Rutherford Jax fl. @ Sep 23 2009, 12:25 PM) [*]718276[/*] QUOTE (TintDude @ Sep 23 2009, 03:24 PM) [*]718274[/*] bag/soak with ammonia, then scrape with NEW razor blades, starting in a small area to make sure you aren't scratching the glass with the blades. the only blades that will harm the glass are carbon steel.. so long as your using stainless your fine
Start at the bottom and work up.
Flow coat gets thicker at the bottom.
