tintdude.com logo
dry adhesive reverse roll tip
metint
Ever find yourself in need of dowel to weight down the reverse-rolled film for better unroll capabilities? Done it on a ladder or scaffold and have the dowel fall to the floor?
Try attaching string to the end of the dowel segment with a screw, and then tie the other end of the string to a belt or belt loop on your pant waist. Be sure the string is long enough for you to perform the drop reverse-roll, yet short enough to keep it from hitting the floor.
The string obviously allows you to more easily retrieve the dowel for use on the next glass or keeps the dowel from doing damage to floor surfaces. thumb.gif
metint
Daaaaammm 40+ looks and no post... evileye.gif Flaugh.gif simple but lame tip or just simply lame...
Mdog
metint
(MDIZZLE @ Jan 10 2004, 09:24 AM)
Mdog
Sprinter
or it hits the window and breaks it, hits the window just right with the screw tip, never know!
metint
(Sprinter @ Jan 14 2004, 08:03 AM)
Contact: tintdude[a]gmail.com
