I need some help with attachment system.
Full Version: I need some help with attachment system.
I need to order tubes of attachment- Dow 995 or IPA for a security film job about 200 linear feet. I was wondering how much to order? It will be about a 1/2" thick (1/4" on the frame and 1/4" on the film) any help would be appreciated because I need to order pretty quick. Thanks
one oz per l/f should cover you. If you need black I may have enough if you need it
QUOTE (TomTint @ Oct 5 2009, 03:44 PM) [*]720899[/*] one oz per l/f should cover you. If you need black I may have enough if you need it I need White Thanks for your help
don't know where you are located but I have gotten 995 from this company http://www.kenseal.com/content/store/sealant-dowcorning.cfm they have stores up and down the east coast. Here's a tech paper from Dow about using 995 for anchoring film http://www.dowcorning.com/content/publishe...TECHTALK995.pdf The 1/4 " your planning on is a minimum per Dow but may not meet you film manny's spec
For a better finish, look into Bondkap. It is a trim that goes over the dow, making a cleaner finish..............
Dow has a calculator on their site that is fairly accurate for calculating how much 995 you will need based on the size of the bead you are laying down.
