2010 Shelby GT500
Full Version: 2010 Shelby GT500
He now wants an alam installed also. Wire diagram? Installogy does not have the 2010 Shelby GT500, I had to use my serial number to find that out!!!
do you need wiring info for this car ??
i can try to help.. lemme know
did you try directwire? from what i was told nothing has changed from a 2009....needs the module though to talk to the computer
send me your email
12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio TunerWire ColorSizered (80A)blue/red (20A)blue/whiteN/A gray/purpleN/A N/Apurple/greenN/AN/Ablue/graypurple/gray (TX), yellow/orange (RX)gray/orange (medium speed CAN)purple/orange (medium speed CAN)N/Ablue/greenyellow/purplegray/brownblue/greenpurple/graygraypurple/whitebrown/yellowblue/green (F)yellow/purple (F)blue/whitepurple/greengreen/browngreen/purplewhiteN/AN/Agray/purplegray/orangeN/Ablue/orangebrn/yel (coupe), brn/yel or brn/pur (convertible)brown/blueN/AN/AN/Ayellow/graygreen/purplesee factory alarm disarmN/ANOT purple/greenN/AN/Ablack/yellow (in), blue/orange (out)purple/greenwhite/orangeN/Awhite/bluegray/yellowgray/orangepurple/whitewhite/purpleblue/whiteblue/orange (L), purple/orange (H)motor part of modulemotor part of modulemotor part of module (convertible)motor part of module (convertible)blue/orange - green/purple (convertible)N/AN/AN/AN/Awhite/redblack/gray(medium speed CAN)(medium speed CAN)blue/greenyellow/greenwhite - white/brown or green - graywhite/purple - white/orange or purple - yellowwhite/green - brown/yellow or green/brn - gray/brnbrown/white - brown/blue or purple/brn - yel/blueN/Apur/grn - grn/wht (F), brn/blue - wht/blue ®blue - yellow/green (without SYNC)blue/green - white/green (without SYNC)brown/purple - white/green (navigation video)blue - gray/orange (SYNC audio)purple/green - brown/white (SYNC audio)N/AN/AN/AN/AN/AN/AirregularN/AN/AN/AN/AN/A(built into radio)PolarityDepth++++++datadatadata--5 wire5 wire5 wire-+-++--+- N.C.- N.C.+- N.C.- N.C.-+--ac- N.O.+- latched- latched- latchedac+----+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-Wire LocationLocationSJB, black 1 pin plug (G), pin 1ignition switch, 7 pin plug, pin 4ignition switch, 7 pin plug, pin 7 or SJB, black 52 pin plug (B), pin 32ignition switch, 7 pin plug, pin 1 or SJB, black 52 pin plug (B), pin 45ignition switch, 7 pin plug, pin 6 or SJB, gray 14 pin plug (A), pin 3ignition switch, 7 pin plug, pin 5 or SJB, black 52 pin plug (B), pin 35PATS Transceiver, 4 pin plug, pins 3 and 4data link conn, 16 pin plug, pin 3 or SJB, blk 52 pin plug (B), pin 37data link conn, 16 pin plug, pin 11 or SJB, blk 52 pin plug (B), pin 38driver kick or SJB, gray 26 pin plug ©, pin 17driver kick or SJB, gray 26 pin plug ©, pin 4driver kick or SJB, black 32 pin plug (D), pin 6driver kick or SJB, black 32 pin plug (D), pin 28passenger kick or SJB, black 32 pin plug (D), pin 27headlight switch or SJB, black 52 pin plug (B), pin 31SJB, black 32 pin plug (D), pin 20hazard switch or SJB, black 52 pin plug (B), pin 48SJB, black 26 pin plug (F), pin 21SJB, black 26 pin plug (F), pin 23headlight switch or SJB, black 52 pin plug (B), pin 30headlight sw or SJB, black 52 pin plug (B), pin 50BCM B, 24 pin plug, pin 5driver kick or SJB, gray 26 pin plug ©, pin 14passenger kick or SJB, gray 26 pin plug ©, pin 2SJB, gray 14 pin plug (A), pin 9SJB, gray 26 pin plug ©, pin 16hood switch or SJB, black 26 pin plug (F), pin 10release switch or SJB, gray 26 pin plug ©, pin 20SJB, black 32 pin plug (D), pin 31driver kick or SJB, gray 26 pin plug ©, pin 9driver kick or SJB, gray 26 pin plug ©, pin 8any fuel injectorclutch switch, 2 pin plug, pins 2 and 1inertia fuel shutoff switch, 3 pin plug, pin 2HVAC Module, 26 pin plug (A), pin 2HVAC Module, 26 pin plug (A), pin 9HVAC Module, 26 pin plug (A), pin 10PCM, top 50 pin plug, pin 3brake switch or SJB, black 52 pin plug (B), pin 40parking brake switch or SJB, gray 26 pin plug ©, pin 1horn switch or SJB, black 52 pin plug (B), pin 41wiper switch, 16 pin plug, pins 16 and 9passenger kick or BCM B, 26 pin plug, pins 18 and 5radio, 24 pin plug, pin 1radio, 24 pin plug, pin 13radio, 24 pin plug, pin 7radio, 24 pin plug, pin 5radio, 24 pin plug, pins 8 and 21radio, 24 pin plug, pins 11 and 12radio, 24 pin plug, pins 9 and 22radio, 24 pin plug, pins 10 and 23radio, 8 pin plug, pins 1 and 2 (F), 5 and 6 ®radio, 16 pin plug, pins 7 and 8radio, 16 pin plug, pins 6 and 14radio, 10 pin plug, pins 3 and 8radio, 16 pin plug, pins 1 and 2radio, 16 pin plug, pins 9 and 10center of dashleft front doorright front doorleft rear quarter panelright rear quarter paneleach front door (F), right side of trunk ®PhotoPhoto</SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN>NoteNote</SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN>Interface ModulesClick here for the complete list of interface products available for this vehicle!Smart Starter Kill Relay Click photo to view a larger version
(*** not all photos have a larger version) Relay Type:Part #:OE Relay Part #:Location: n/a n/a n/aNotes:n/aAlternate Part Notes:n/a12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio TunerWire ColorSizered (80A)blue/red (20A)blue/whiteN/A gray/purpleN/A N/Apurple/greenN/AN/Ablue/graypurple/gray (TX), yellow/orange (RX)gray/orange (medium speed CAN)purple/orange (medium speed CAN)N/Ablue/greenyellow/purplegray/brownblue/greenpurple/graygraypurple/whitebrown/yellowblue/green (F)yellow/purple (F)blue/whitepurple/greengreen/browngreen/purplewhiteN/AN/Agray/purplegray/orangeN/Ablue/orangebrn/yel (coupe), brn/yel or brn/pur (convertible)brown/blueN/AN/AN/Ayellow/graygreen/purplesee factory alarm disarmN/ANOT purple/greenN/AN/Ablack/yellow (in), blue/orange (out)purple/greenwhite/orangeN/Awhite/bluegray/yellowgray/orangepurple/whitewhite/purpleblue/whiteblue/orange (L), purple/orange (H)motor part of modulemotor part of modulemotor part of module (convertible)motor part of module (convertible)blue/orange - green/purple (convertible)N/AN/AN/AN/Awhite/redblack/gray(medium speed CAN)(medium speed CAN)blue/greenyellow/greenwhite - white/brown or green - graywhite/purple - white/orange or purple - yellowwhite/green - brown/yellow or green/brn - gray/brnbrown/white - brown/blue or purple/brn - yel/blueN/Apur/grn - grn/wht (F), brn/blue - wht/blue ®blue - yellow/green (without SYNC)blue/green - white/green (without SYNC)brown/purple - white/green (navigation video)blue - gray/orange (SYNC audio)purple/green - brown/white (SYNC audio)N/AN/AN/AN/AN/AN/AirregularN/AN/AN/AN/AN/A(built into radio)PolarityDepth++++++datadatadata--5 wire5 wire5 wire-+-++--+- N.C.- N.C.+- N.C.- N.C.-+--ac- N.O.+- latched- latched- latchedac+----+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-Wire LocationLocationSJB, black 1 pin plug (G), pin 1ignition switch, 7 pin plug, pin 4ignition switch, 7 pin plug, pin 7 or SJB, black 52 pin plug (B), pin 32ignition switch, 7 pin plug, pin 1 or SJB, black 52 pin plug (B), pin 45ignition switch, 7 pin plug, pin 6 or SJB, gray 14 pin plug (A), pin 3ignition switch, 7 pin plug, pin 5 or SJB, black 52 pin plug (B), pin 35PATS Transceiver, 4 pin plug, pins 3 and 4data link conn, 16 pin plug, pin 3 or SJB, blk 52 pin plug (B), pin 37data link conn, 16 pin plug, pin 11 or SJB, blk 52 pin plug (B), pin 38driver kick or SJB, gray 26 pin plug ©, pin 17driver kick or SJB, gray 26 pin plug ©, pin 4driver kick or SJB, black 32 pin plug (D), pin 6driver kick or SJB, black 32 pin plug (D), pin 28passenger kick or SJB, black 32 pin plug (D), pin 27headlight switch or SJB, black 52 pin plug (B), pin 31SJB, black 32 pin plug (D), pin 20hazard switch or SJB, black 52 pin plug (B), pin 48SJB, black 26 pin plug (F), pin 21SJB, black 26 pin plug (F), pin 23headlight switch or SJB, black 52 pin plug (B), pin 30headlight sw or SJB, black 52 pin plug (B), pin 50BCM B, 24 pin plug, pin 5driver kick or SJB, gray 26 pin plug ©, pin 14passenger kick or SJB, gray 26 pin plug ©, pin 2SJB, gray 14 pin plug (A), pin 9SJB, gray 26 pin plug ©, pin 16hood switch or SJB, black 26 pin plug (F), pin 10release switch or SJB, gray 26 pin plug ©, pin 20SJB, black 32 pin plug (D), pin 31driver kick or SJB, gray 26 pin plug ©, pin 9driver kick or SJB, gray 26 pin plug ©, pin 8any fuel injectorclutch switch, 2 pin plug, pins 2 and 1inertia fuel shutoff switch, 3 pin plug, pin 2HVAC Module, 26 pin plug (A), pin 2HVAC Module, 26 pin plug (A), pin 9HVAC Module, 26 pin plug (A), pin 10PCM, top 50 pin plug, pin 3brake switch or SJB, black 52 pin plug (B), pin 40parking brake switch or SJB, gray 26 pin plug ©, pin 1horn switch or SJB, black 52 pin plug (B), pin 41wiper switch, 16 pin plug, pins 16 and 9passenger kick or BCM B, 26 pin plug, pins 18 and 5radio, 24 pin plug, pin 1radio, 24 pin plug, pin 13radio, 24 pin plug, pin 7radio, 24 pin plug, pin 5radio, 24 pin plug, pins 8 and 21radio, 24 pin plug, pins 11 and 12radio, 24 pin plug, pins 9 and 22radio, 24 pin plug, pins 10 and 23radio, 8 pin plug, pins 1 and 2 (F), 5 and 6 ®radio, 16 pin plug, pins 7 and 8radio, 16 pin plug, pins 6 and 14radio, 10 pin plug, pins 3 and 8radio, 16 pin plug, pins 1 and 2radio, 16 pin plug, pins 9 and 10center of dashleft front doorright front doorleft rear quarter panelright rear quarter paneleach front door (F), right side of trunk ®PhotoPhoto</SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN>NoteNote</SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN>Interface ModulesClick here for the complete list of interface products available for this vehicle!Smart Starter Kill Relay Click photo to view a larger version (*** not all photos have a larger version) Relay Type:Part #:OE Relay Part #:Location: n/a n/a n/aNotes:n/aAlternate Part Notes:n/a12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio TunerWire ColorSizered (80A)blue/red (20A)blue/whiteN/A gray/purpleN/A N/Apurple/greenN/AN/Ablue/graypurple/gray (TX), yellow/orange (RX)gray/orange (medium speed CAN)purple/orange (medium speed CAN)N/Ablue/greenyellow/purplegray/brownblue/greenpurple/graygraypurple/whitebrown/yellowblue/green (F)yellow/purple (F)blue/whitepurple/greengreen/browngreen/purplewhiteN/AN/Agray/purplegray/orangeN/Ablue/orangebrn/yel (coupe), brn/yel or brn/pur (convertible)brown/blueN/AN/AN/Ayellow/graygreen/purplesee factory alarm disarmN/ANOT purple/greenN/AN/Ablack/yellow (in), blue/orange (out)purple/greenwhite/orangeN/Awhite/bluegray/yellowgray/orangepurple/whitewhite/purpleblue/whiteblue/orange (L), purple/orange (H)motor part of modulemotor part of modulemotor part of module (convertible)motor part of module (convertible)blue/orange - green/purple (convertible)N/AN/AN/AN/Awhite/redblack/gray(medium speed CAN)(medium speed CAN)blue/greenyellow/greenwhite - white/brown or green - graywhite/purple - white/orange or purple - yellowwhite/green - brown/yellow or green/brn - gray/brnbrown/white - brown/blue or purple/brn - yel/blueN/Apur/grn - grn/wht (F), brn/blue - wht/blue ®blue - yellow/green (without SYNC)blue/green - white/green (without SYNC)brown/purple - white/green (navigation video)blue - gray/orange (SYNC audio)purple/green - brown/white (SYNC audio)N/AN/AN/AN/AN/AN/AirregularN/AN/AN/AN/AN/A(built into radio)PolarityDepth++++++datadatadata--5 wire5 wire5 wire-+-++--+- N.C.- N.C.+- N.C.- N.C.-+--ac- N.O.+- latched- latched- latchedac+----+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-Wire LocationLocationSJB, black 1 pin plug (G), pin 1ignition switch, 7 pin plug, pin 4ignition switch, 7 pin plug, pin 7 or SJB, black 52 pin plug (B), pin 32ignition switch, 7 pin plug, pin 1 or SJB, black 52 pin plug (B), pin 45ignition switch, 7 pin plug, pin 6 or SJB, gray 14 pin plug (A), pin 3ignition switch, 7 pin plug, pin 5 or SJB, black 52 pin plug (B), pin 35PATS Transceiver, 4 pin plug, pins 3 and 4data link conn, 16 pin plug, pin 3 or SJB, blk 52 pin plug (B), pin 37data link conn, 16 pin plug, pin 11 or SJB, blk 52 pin plug (B), pin 38driver kick or SJB, gray 26 pin plug ©, pin 17driver kick or SJB, gray 26 pin plug ©, pin 4driver kick or SJB, black 32 pin plug (D), pin 6driver kick or SJB, black 32 pin plug (D), pin 28passenger kick or SJB, black 32 pin plug (D), pin 27headlight switch or SJB, black 52 pin plug (B), pin 31SJB, black 32 pin plug (D), pin 20hazard switch or SJB, black 52 pin plug (B), pin 48SJB, black 26 pin plug (F), pin 21SJB, black 26 pin plug (F), pin 23headlight switch or SJB, black 52 pin plug (B), pin 30headlight sw or SJB, black 52 pin plug (B), pin 50BCM B, 24 pin plug, pin 5driver kick or SJB, gray 26 pin plug ©, pin 14passenger kick or SJB, gray 26 pin plug ©, pin 2SJB, gray 14 pin plug (A), pin 9SJB, gray 26 pin plug ©, pin 16hood switch or SJB, black 26 pin plug (F), pin 10release switch or SJB, gray 26 pin plug ©, pin 20SJB, black 32 pin plug (D), pin 31driver kick or SJB, gray 26 pin plug ©, pin 9driver kick or SJB, gray 26 pin plug ©, pin 8any fuel injectorclutch switch, 2 pin plug, pins 2 and 1inertia fuel shutoff switch, 3 pin plug, pin 2HVAC Module, 26 pin plug (A), pin 2HVAC Module, 26 pin plug (A), pin 9HVAC Module, 26 pin plug (A), pin 10PCM, top 50 pin plug, pin 3brake switch or SJB, black 52 pin plug (B), pin 40parking brake switch or SJB, gray 26 pin plug ©, pin 1horn switch or SJB, black 52 pin plug (B), pin 41wiper switch, 16 pin plug, pins 16 and 9passenger kick or BCM B, 26 pin plug, pins 18 and 5radio, 24 pin plug, pin 1radio, 24 pin plug, pin 13radio, 24 pin plug, pin 7radio, 24 pin plug, pin 5radio, 24 pin plug, pins 8 and 21radio, 24 pin plug, pins 11 and 12radio, 24 pin plug, pins 9 and 22radio, 24 pin plug, pins 10 and 23radio, 8 pin plug, pins 1 and 2 (F), 5 and 6 ®radio, 16 pin plug, pins 7 and 8radio, 16 pin plug, pins 6 and 14radio, 10 pin plug, pins 3 and 8radio, 16 pin plug, pins 1 and 2radio, 16 pin plug, pins 9 and 10center of dashleft front doorright front doorleft rear quarter panelright rear quarter paneleach front door (F), right side of trunk ®PhotoPhoto</SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN>NoteNote</SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN>Interface ModulesClick here for the complete list of interface products available for this vehicle!Smart Starter Kill Relay Click photo to view a larger version (*** not all photos have a larger version) Relay Type:Part #:OE Relay Part #:Location: n/a n/a n/aNotes:n/aAlternate Part Notes:n/alet me know if you got the email?
