tintdude.com logo
05 silverado 1500
Full Version: 05 silverado 1500
tint_audiopros
whats up folks, the last 3 mornings I have had to reset the clock on my radio, its the double din 6 disc gm radio. The radio pre-sets are all still programmed just the clock? dunno.gif The clock hasn't just went back to 12:00 like this morning I got in it was really 9am and it said 3 or something, any ideas? It's definitely a memory issue. The battery is about 1 year old.
Jeff Rutherford Jax fl.
QUOTE (tint_audiopros @ Oct 20 2009, 12:56 PM) [*]724235[/*]
i would think to check the battery,,,might not be holding a charge like it use to...had something simular happen to me....was explained that cold chranking amp was not good, but the charge of the battery was fine. thought it was weard the first time i heard it...
HoLlYwOoD
If your battery is only a year old it should have a warranty on it. Take that biatch back and tell them to test it or make it up for you. I used to work at an autoparts store. There are quite a few batteries that come back within a year.
ClassOnGlass
QUOTE (HoLlYwOoD @ Oct 22 2009, 06:31 AM) [*]724588[/*]
gm has recently had a bad run of batteries get it checked
TTS
I would think if the battery couldn't power the clock in the radio it sure as heck wouldn't be able to crank over the engine dunno.gif
Booms2Go
QUOTE (TTS @ Oct 22 2009, 12:32 PM) [*]724655[/*]
its crazy...mine had just enough to crank the car, but it would reset all memory...i was told my battery didnt have the cold cranking amps it needed...but had enough amps to start it...im with you it just dont seem right?
Contact: tintdude[a]gmail.com
