tintdude.com logo
2010 cadillac cts-v
Full Version: 2010 cadillac cts-v
hacklhead
need car security wiring for alarm remot start
Zrok
all i can find is a 2009 CTS. if its the same, here's what i have access to..
_____________________________________
Security
WIRE COLOR POLARITY LOCATION
All Door Trigger
USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE,
LF Latch GRAY/BLACK (-) AT DRIVER DOOR MODULE IN DRIVER DOOR
RF Latch BLACK/WHITE (-) AT PASSENGER DOOR MODULE IN PASSENGER DOOR
LR Latch LIGHT BLUE/WHITE OR DARK BLUE/WHITE (-) AT BCM MODULE UNDER STEERING COLUMN
RR Latch LIGHT GREEN/BLACK (-) AT BCM MODULE UNDER STEERING COLUMN
Trunk Trigger PINK/BLACK (-) AT BCM MODULE UNDER STEERING COLUMN
Parking Lights BROWN (-) AT VEHICLE LIGHT SWITCH
ALSO DARK BLUE (-) AT REAR FUSEBOX
Convenience
LF Pk Lt Bulb VIOLET (+) AT FRONT LEFT PARKING LAMP
RF Pk Lt Bulb BROWN/WHITE (+) AT FRONT RIGHT PARKING LAMP
LR Pk Lt Bulb VIOLET (+) AT REAR LEFT PARKING LAMP
RR Pk Lt Bulb BROWN/WHITE (+) AT REAR LEFT PARKING LAMP
Trnk Release BLACK/WHITE (+) AT VEHICLE REAR FUSEBOX
ALSO AT TRUNK RELEASE MOTOR IN TRUNK
Fuel Dr Release PINK (-) AT BCM MODULE UNDER STEERING COLUMN
Remote Start
Anti-Theft Type GM PASSKEY IIIĀ® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Speed Sense DARK GREEN/WHITE (AC) RADIO HARNESS
ALSO AT ABS CONTROL MODULE NEAR MASTER CYLINDER
Reverse Lights LIGHT GREEN (+) AT BCM MODULE UNDER DRIVER SIDE DASH
Horn BLACK (-) IN HARNESS AT STEERING COLUMN
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock LIGHT BLUE (-) AT BCM MODULE UNDER STEERING COLUMN
THESE WIRES CONTROL THE REAR DOORS ONLY, FOR THE FRONT DOORS YOU MUST 5 WIRE EACH LOCK MOTOR,
PowerLock LIGHT GREEN (+) AT BCM MODULE UNDER STEERING COLUMN
Driver Mtr Unlock TAN (REV) AT DRIVER DOOR MODULE IN DRIVER DOOR
Driver Mtr Lock LIGHT GREEN/BLACK (REV) AT DRIVER DOOR MODULE IN DRIVER DOOR
Pas Mtr Unlock TAN (REV) AT PASSENGER DOOR MODULE IN PASSENGER DOOR
Pas Mtr Lock DARK BLUE (REV) AT PASSENGER DOOR MODULE IN PASSENGER DOOR
hacklhead
thanks for the info - this car is the push button cts-v i know i fogot to mention that. i cant find anything on this car
Contact: tintdude[a]gmail.com
