tintdude.com logo
ComputerCut is the biggest Joke in the tint industry !!!
jaketuckey
Well I have been using/fighting with this ComputerCut system for the last year at our other location. I have been tinting auto glass for over 22 years and in January of this year I transfered to one of our other shops with a computer cut system.
I have to say it is the biggest joke in the tint industry!!! It is a waste of time and material. Cuts don't fit and need trimmed or are the wrong size all together. Film is constantly jamming up in the cutter due to SolarGard changing their liner a few months ago to a more rubber material and static is a huge issue. Rollers have been kept up and machine is always taken care of.
thatsnappyguy
i cant say much about computer cut, i use tint tek and sometimes you run into some problems with the patterns being a little off but that problem exist with all the systems. as far as the tint issue...thats your bad for gettin a program through you tint company. change film, or can you?
Limo Tint Larry
Have you contacted compcut or your rep for assistance? Not saying your problems aren't legitimate but I've encountered several situations where a lack of initial training wreaked havoc on the usability of the software/plotter.
scottydosnntkno
QUOTE (Limo Tint Larry @ Nov 6 2009, 12:15 PM) [*]727562[/*]
bingo.gif when I first got my plotter i burned through a ton of vinyl trying to figure out why it wasn't cutting the right size, and making a million adjustments in the program trying to fix it. eventually I called the rep and he had me clean install everything and push this magical code of buttons on the plotter and I was able to measure the cut and then put in the number and it would compensate for it. easy as pie now beer.gif
Jeff Rutherford Jax fl.
this is a joke...been using it for 9years now and never had a problem with patterns...as far as graphics they are way ahead of the game, with importing more than one pattern. i have never had the problem with eating threw film.
You have downloaded 9878 pattens and have cut 11980 times.
The last time you used the ComputerCut application was on:
11/06/2009.
that is how many cuts ive done with coputercut and will only say that your problems would be mainly operators error? with this in mind there is alot of veribles and would say also "i use atr and platnium plus bye Llumar" on this note i would would say keep at it?
this is what computercut does for my shop here in jacksoville
alberts316
I don't have too many issues with my computercut or the film I feed thru it dunno.gif
Limo Tint Larry
Be sure to get a tinsel strip to mount behind the plotter. It rests against the film as it passes through and helps disperse the static electricity. Some films are more troublesome than others.
Call your service center they should supply one n/c beer.gif
PJF
QUOTE (jaketuckey @ Nov 6 2009, 12:23 PM) [*]727534[/*]
That is surprising. Kevin has always seemed to have that system fairly dialed in. I have not heard many complain over the years.
SuperSetKing
film jams are caused from
1. film not being loaded straight and maintaining this. test feeding it to make sure and keeping an eye on it between cuts.
2. pen pressure being set to great, or blade depth out to much, or both.
Static
1. use a tinsil strip or contact the stand maker and get different media stands.
If your machine is set up and you know how to maintain it these are not issues
as for templates not fitting, I think its to be said no on likes laying others patterns. WE ALL CUT THE BEST PATTERNS IF YOU ASK US!! lol
work with what you got. make it work for you. I loved having any systems for back windows and suv BG's
Brenter The Tinter
I had computer cut from sg about 3 years ago... I agree its a waste of money for my use... the patterns never fit like I wanted them too and I couldnt get a micro edge like I can with my blade. No sense in paying for something you will have to retrim anyway. I never had any problems with the plotter though... I do vinyl graphics and signs so i'm fluent with the machines. I do agree though the patterns did suck... keep in mind this was three years ago so things might have changed by now so i guess my opinion doesnt really count on computer cut anymore.
watchdaride
the patterns before 2000 arent as good as the newer ones. There is a learning curve . I got a new plotter last winter and there was about a month of learning curve . It not as easy as vinyl . Gary at computercut been in the business for many years and he knows his stuff.
jaketuckey
I owned my own sign company for 9 years doing signs and now how to use the cutter and the setup perfect. The HP Supreme film was running perfect up till this year and now it sucks in the cutter. SG admits that they changed the backer and now it is not computercut friendly. We do tons of dealer work and clearshield and use it all the time.
thatsnappyguy
i was talking to one of the big wigs from digicut a while back and he was explaining to me the system. im very impressed with the way it works. perfect for dealer work. it wont allow you to run darker than legal film through on the highlighted windows, it keeps track of the film inch by inch. nothin i would ever consider using, but it is a very tightly ran ship they got. the only thing i dont like it the fact that you have to run thier film through, which sucks because you really have no idea what kind of film you are installing but are still warrantying it .
SuperSetKing
QUOTE (thatsnappyguy @ Nov 10 2009, 10:01 AM) [*]728222[/*]
yea the whole system is set up for the customers needs to protect the stock and control. I worked for them for a lil bit
wetintcars.com
Switch films if you're having that much trouble.
Brenter The Tinter
QUOTE (wetintcars.com @ Nov 13 2009, 06:41 AM) [*]728910[/*]
You have never had to retrim the top edge because the edge it cut was not a good fit?
tint star
QUOTE (Jeff Rutherford Jax fl. @ Nov 6 2009, 03:56 PM) [*]727588[/*]
11/06/2009.
flat rock stan
QUOTE (thatsnappyguy @ Nov 10 2009, 08:01 AM) [*]728222[/*]
QUOTE (flat rock stan @ Nov 14 2009, 12:51 AM) [*]729036[/*]
i pay extra for that not much to have a data base of all film run mumbers and it will keep track of all invatory...i will always stick to my cc dealership...best for graphics since multiple patterns can be imported together on the same cut screen...there isnt to many other cut programs that allow this
thatsnappyguy
QUOTE (Jeff Rutherford Jax fl. @ Nov 14 2009, 07:07 AM) [*]729050[/*]
my tint tek does allow me to do this. mainly what i do it design everything myself on flexi, then import it to tint tek.
wetintcars.com
QUOTE (Brenter The Tinter @ Nov 13 2009, 09:47 PM) [*]729010[/*]
Not often. Now with version 7 you can fix that sort of thing easily within the program.
ComputerCut is still one of the best business decisions I have made. biggthumpup.gif
Contact: tintdude[a]gmail.com
