tintdude.com logo
2009 Honda Accord 4dr
Full Version: 2009 Honda Accord 4dr
Alcala
Never tinted any honda before! Gonna try one tomorrow for my buddy as practice. You guys got any tips to make it easier on me?
Fronts, Rear, Qtrs, BG? thanks
solar protect
(Alcala @ Nov 6 2009, 09:12 PM) [*]727571[/*]
icon_yoda.gif :
front quarters, problems could cause
Jeff Rutherford Jax fl.
front quaters are on fit and civic, not accord....does have rear quaters
dry shrink the back glass with powder,dryer sheet, or bar soap..do some research on dry shrinking....the rear glass should take the most of your time..there isnt alot of curve but enough to cause some trouble..you can sand the defrost with 2000 and it will stick better, depending on the type of film you use?
the rear quarters you could use more slip solution to tuck it behind the rubber, doing those last if you change the solution for those? if you have black vynal you could easly use the scrap from your cut to black out the area on the outside and not worry about tucking them...or leave it clear doesnt look bad either way...
on that note you shouldnt have any troubles and if you do? you know where to ask..here on tintdude
scottydosnntkno
(Jeff Rutherford Jax fl. @ Nov 6 2009, 03:21 PM) [*]727596[/*]
all these years, and I've never thought about doing the quarters last lol2.gif I always have had two bottles, one normal and one stronger for BG's/quarters like fusions/accords. I usually use one bottle total per car, so it would be smart to do the doors first and then add a tad more soap for the rest. durrrrr blink.gif
yz101
May be easier to pull the panels if you want to make the doors REALLY simple. Three screws on each panel. Two behind the handle, and one in the arm rest. Then pop it off . biggthumpup.gif
Monique
Why pull the panels when it's totally un-neccessary as the rollups are so easy. The back glass is a bit tougher than the last generation and begs for a dry shrink and 0000 steel wool is a must. Just don't use anything to harsh as that glass WILL scratch. The quarters just need to be fit correctly, no big deal.
one slick tinter
hmmmmmmm.gif Funny, I have never used steel wool on the new accord and never had any problems....i do alot of those cars too. dunno.gif
And I just use my reg. slip solution..it should slide behind those rubbers on the quarter glass easily.
tint51
(Monique @ Nov 7 2009, 12:02 AM) [*]727701[/*]
If new to tinting than pull panels.. if you have 1-2 exp. then leave them and try it..
twotint
I'm am backwards from a lot of people. I started out tucking film, but now I prefer to remove the panels on just about all cars. I still leave them on when I know their really easy. I found by pulling the panels I can get the tint farther below the belt mldg and only have to make one pass to seat the bottom then pop the panel right on, no fighting water coming back up.
yz101
(Monique @ Nov 7 2009, 02:02 AM) [*]727701[/*]
The person asked for tips to make the first one easy. I didn't think giving a person options would offend your "GREATNESS". Please allow me to apologize. dunno.gif
ISTHATFACTORY?
I pull the rear qtr's ... Looks alot better ... Unless they changed from 08, and now you don't have to? dunno.gif
(scottydosnntkno @ Nov 6 2009, 04:45 PM) [*]727603[/*]
funny funny guy mr i dont know...read it again and you might understand...i never said this is how i do them! a rookie would want more slip to tuck quaters behind the rubbers on these quarters
blade
because it's a few screws and they pop right off. it would take longer to try and tuck the film properly & squeegee it than it would to actually just pull the panel. atleast for me. Flaugh.gif
tint51
(blade @ Nov 10 2009, 10:38 AM) [*]728242[/*]
because it's a few screws and they pop right off. it would take longer to try and tuck the film properly squeegee it than it would to actually just pull the panel. atleast for me. Flaugh.gif
I agree did them the other day.. a few screws about 5 mins and you are clear... imok.gif
a1-wintinter
I do Accords everyday and dont use steel wool or pull off the panels, and I never have any trouble with them. However it is much easier to use a couple of fiber sticks and pry the top of the door panels back, then use the fiber sticks on each side of the panel to make some room at the top of the panel.
tint51
(a1-wintinter @ Nov 10 2009, 12:44 PM) [*]728283[/*]
a1-wintinter
(tint51 @ Nov 10 2009, 11:46 AM) [*]728284[/*]
a little faster for me, no need to shrink the doors
Contact: tintdude[a]gmail.com
