Caddy with ON-STar Annt.
Full Version: Caddy with ON-STar Annt.
how does eveyone handle the new caddys with the ON Star Anntena damn near in the middle of the rear glass. I don't like when I haveto cut around it, but I take a chance when I remove it and place it higher on the rear glass. I use 3M heavy duty double sided tape to put them back on and have only had to pay the dealership for one, the first on that i ever removed. how do yall hadle that car?
your referring to the exterior antenna with the square base?
yea thats the one
OK, these are on a few different types of cars..what I do is use a scraper on each side t oloosen it, then take a hard card , soap and saw it back and forth till it pops of with the "white patch still in tact.
do thesame to the inside box for the antenna. tint as normal. cut a square out where you want it to go back on, stick it on after the white part hada chance to dry"(use heatgun on low to dry it if you want...it will stick as thoughyou never took it off whe ndone right) put a bit of silicone around the perimeter of the outside antenna to insure good bond
I do something like that but I prefer to put new tape on to ensure great bond after paying for the first anntena. I for get how much it was but either way I didn't enjoy cutting that check.
And I place it up in toward the top of window, where they won't notice I had to cut the film. like in the upper right corner. and the heat on the tape is a must.
you shouldn't see any cut in the film if your removing it completly then replacing it..the"square" cut out you make in the film is a slightly smaller square than the square of the antenna ( the antenna slightly overlaps the edge of the cut out..no edge to see this way no matter where the antenna is located)
I C
anyother methods?
yep, i charge $20 for this process. they don't like it, they can take their POS caddy somewhere else. i'm being paid to tint their car, not fock around with old style cell antennaes. plus, those rolls of the good double sided adhesive aren't cheap.
I use a slammer to pry off the old antenea then I use a wire wheel to quickly remove the old tape from the antenea. I saw a post were a guy used dental floss like a rope saw that would be worth a try.
Any way there is a place out here that sells 'Relocation Kits' for cell phone antenea they cost a $1 the are basically 3M two face tape in the exact shape of the antenea they give you 2 per kit 1 outside one inside in the shape needed Find a place near you that sells car stereo supplies (wire and Kits) they should have it or call 631-588-0600 ask for Rob. he'll help you
i remove those, tint the glass and put them back on, i keep a roll of the 3m tape for this.
I heat up the glass and then plae a razor blade in the corner and push down with a white card. And then peel up. Same thing on the inside. Than place some new double sided tape and your back in business.
That 3M double sided tape light gray with the red backing is expensive but worth its weight in gold, unlike their window film!
QUOTE (Ecliptic @ May 17 2004, 05:40 PM) I heat up the glass and then place a razor blade in the corner and push down with a white card. And then peel up. Same thing on the inside. Than place some new double sided tape and your back in business. Same here
lol, all these cheapasses lost their free year of onstar so now you can just yank em'
QUOTE (Fiveofeen @ Jun 19 2007, 12:05 AM) [*]516972[/*] lol, all these cheapasses lost their free year of onstar so now you can just yank em' QUOTE (one slick tinter @ Jun 19 2007, 05:57 AM) [*]517003[/*] sniffin the wrong stuff again
