Multimeter leads?
naughtydog
Feb 11 2004, 02:51 PM
I am on the lookout for some leads for my multimeter that have a sharp point and hoook affire,...let me explain. :booga
One of the problems with using a meter is that you have to generally bare back the insulation. I want to be able to poke the wire with the sharp prong and get my reading.
I have attached a poor drawing of what I have in mind...I'm sure trhey exist--dont know where??
Naughtydog
doh..image did not show
naughtydog
Feb 11 2004, 02:52 PM
this is a jpg - should see it now
ND
Exact-Oh
Feb 11 2004, 02:54 PM
Ah, mine aren't like that. Mine are finger busters, poke the finger when it slips off the wire.
wndotint
Feb 11 2004, 08:35 PM
same here. I just keep my tip very sharp and it usually doesn't slip off the wire. I don't use a multimeter, I use a Snap-On computer-safe circuit tester. EECT301A.
Exact-Oh
Feb 14 2004, 10:00 AM
I use the Snap-On Vantage unit. It has a nice multi-meter, and a fairly quick responding oscilliscope, with is nice when testing for tachometer signals or pulse type signals. It is a little expensive for what I am doing, but my hubby the mechanic uses it also for testing computer components/sensors.
toodark
Feb 14 2004, 02:35 PM
I bought my form the snap-on guy.
RaduF
May 27 2004, 10:26 PM
Please visit Parrot Test clip Invention's site Parrot Test Leads Invention to find a new Gripping test clip with a metal tip. The connection is made between the new metal tip and a steel hooked rod. The connection has a low resitence as the metal tip is directly connected to the leads. The accesibility to narrow places is good as well as the operator -signal insulation. The tip maybe is not as sharp as you want but you can try to use it in many applications. Radu Filipescu Parrot Invent
Sisqouc
Oct 2 2004, 06:09 PM
Near-topic: Not EXACTLY what you asked for, but check the whole site they've got some insane stuff. http://www.sandman.com/repair.htmlThe site has lots-o-phone stuff...speaking of which: Warning Off Topic does anyone know of a source to buy phone gag device which causes the "mark's" phone to dial wrong numbers 25% of outgoing calls. Used to have cataloge with that in it.
Contact: tintdude[a]gmail.com
