Advertise on TintDude! Contact us for details.
Contact us at admin@tintdude.com
spacer
spacer
Sign in to follow this
Guest mikehende
non see-through tint?
Guest mikehende
My Garage door has 4 windows in the middle made of plexiglass and I bought a tint called "Smoke" which looks dark from the outside but whenever there is any type of light inside the garage especially at night, you can see inside the Garage. I would like to get a tint such that no one will be able to see through no matter how bright the light is inside the garage. I have seen a Pub nearby that has a sort of "silver" looking tint and you can't see anything at all inside of the pub even if you are standing right at the door on the outside, this is what I need. Any ideas here please? If you guys come up with something, can I use a "spray" tint? Thanks.
Share this post
Link to post
Guest darkdan
Tint doesn't work the way you want it to.
Tint also doesn't like to stick to plexiglass very long.
Paint the windows with krylon.
Share this post
Link to post
It doesn't work that way at night with lights on inside. But, bars are kept pretty darkly lit. The side with the most light is always going to be seen through the film. It's a given.
Share this post
Link to post
Guest mikehende
Appreciate the quick response guys
1] If I use "paint", looking through the window from the inside, will this still allow me to see the outside as with the tint?
2] When you say "Krylon", is this "spray" paint you are referring to? If so, any particular color I should be getting?
Thanks.
Share this post
Link to post
Mike..I had the the exact same problem..when I built my shop last yr..the lights are so bright that it lights up the whole outside..yet I wanted to see out . Same dilema ..4 windows on the garage door.
I just used black vinyl to blacken them right out and then cut out 2 tiny peep holes so when I get right up to the door..I can see out OK yet the peep holes are small enough that you don't notice them from the outside at night
Share this post
Link to post
Guest mikehende
The problem with the peep holes for me will be that I will have to go up close to the door and will not be able to see outside from the back of the Garage where I am most of the times. Guess there's no way to get what I want huh? If by chance I do come up with something, I will post back here, thanks fellas!
Share this post
Link to post
darkdan said:
If you do come up with something....patent it and you'll be rich.
[*]336597
The house jobs we all must lose because of this film not existing
Share this post
Link to post
Guest mikehende
Well, maybe a paint or film might not be the answer here, maybe there is a certain type of window material that does this, I will look into this and get back to you guys.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
