Sign in to follow this
Followers 0
Guest Ultimate Detailing
How to hook up power washer to a water tank
11 posts in this topic
I'm starting up a mobile car detailing business in New Jersey and I tried hooking my power washer to of baby pool I have in my back yard but the power washer wasn't getting any water but if I get a water tank will it get water or is there a special power washer I need or sometihng please help me out thanks a alot guys
Share this post
Link to post
Water has to move, therefore gravity will make water sit still if nothing is making it move. Go to your local hard wood store and buy a water pump.
Connect water tank to a on/off switch, run a hose of the end of the switch, which runs into a pump that pushes the water through the hoses. I ran a another big hose off the end of the pump, so I can extend out as far as I need. The pressure washer connects to the end of the garden hose.
Share this post
Link to post
if I put a on/off switch at the bottom of the tank would gravaty bring the water to the power washer?? and if nto what kind of pump to get?? just a regular pond or fountain pump would do??
Share this post
Link to post
No, off of the on/off switch needs a hose or in my case copper pipe that connects on the in. side of the pump( I use a pond pump and it works perfect) the pump will send the water into a another hose the connects to the pressure washer. Remember, that gravity has very little pressure therefore you need to create it for the water to move into your pressure washer!
on/off-----------------pump-------------------pressure washer
Edited by WASHBOY
Share this post
Link to post
I agree, I tried doing the gravity feed deal at first, it works ok until the level gets low.
When I did houses, I just used a 100ft hose and connected to their water supply.
Never did autos mobile, you will definately need a pump if you have to rely on tanked water. :evilgrin
Share this post
Link to post
You are probably using one of those home center pressure washers. I professional unit will draw the water from a tank just fine. Some of the online detail suppliers sell great units.
Share this post
Link to post
I use a 4000 psi. pressure washer that I can turn the pressure up or down. It has a 13 hp Honda motor and a General pump on it. The best pumps are Cat. or General. Also I put a By-Pass hose on it so I can leave the pressure washer running while I am putting soap on the car. What happens is the water is circulating threw the water tank and the pressure washer. Like a radiator on a car. It is very simple to do. This machine sucks the water out of the tank. You don't need a small motor to pull water from your tank. It will save you alot of time, Not having to go back and fourth turning your pressure washer off because you might burn up the valves in the pump. If you want I will send pic. of my unit and show you what am talking about. The down side of this is this pressure washer was @ 1200.00 dollars. But it is a belt driven not a shaft driven like most pressure washers. If you have any question send me a PM. :dunno
Share this post
Link to post
I use a 4000 psi. pressure washer that I can turn the pressure up or down. It has a 13 hp Honda motor and a General pump on it. The best pumps are Cat. or General. Also I put a By-Pass hose on it so I can leave the pressure washer running while I am putting soap on the car. What happens is the water is circulating threw the water tank and the pressure washer. Like a radiator on a car. It is very simple to do. This machine sucks the water out of the tank. You don't need a small motor to pull water from your tank. It will save you alot of time, Not having to go back and fourth turning your pressure washer off because you might burn up the valves in the pump. If you want I will send pic. of my unit and show you what am talking about. The down side of this is this pressure washer was @ 1200.00 dollars. But it is a belt driven not a shaft driven like most pressure washers. If you have any question send me a PM. :gasp
Hey tmd325
Can you send me a pic of the unit that you are talking about?
Thanks,
Mike
Share this post
Link to post
I use a 4000 psi. pressure washer that I can turn the pressure up or down. It has a 13 hp Honda motor and a General pump on it. The best pumps are Cat. or General. Also I put a By-Pass hose on it so I can leave the pressure washer running while I am putting soap on the car. What happens is the water is circulating threw the water tank and the pressure washer. Like a radiator on a car. It is very simple to do. This machine sucks the water out of the tank. You don't need a small motor to pull water from your tank. It will save you alot of time, Not having to go back and fourth turning your pressure washer off because you might burn up the valves in the pump. If you want I will send pic. of my unit and show you what am talking about. The down side of this is this pressure washer was @ 1200.00 dollars. But it is a belt driven not a shaft driven like most pressure washers. If you have any question send me a PM. :lol
I would also like to c a pic of the by-pass that sounds like a great idea but im a lil confused on how to do it
and a little common sence tip make sure the lid is off the tank when runnin the pw or the gravity will not feed very well
Share this post
Link to post
I use a 4000 psi. pressure washer that I can turn the pressure up or down. It has a 13 hp Honda motor and a General pump on it. The best pumps are Cat. or General. Also I put a By-Pass hose on it so I can leave the pressure washer running while I am putting soap on the car. What happens is the water is circulating threw the water tank and the pressure washer. Like a radiator on a car. It is very simple to do. This machine sucks the water out of the tank. You don't need a small motor to pull water from your tank. It will save you alot of time, Not having to go back and fourth turning your pressure washer off because you might burn up the valves in the pump. If you want I will send pic. of my unit and show you what am talking about. The down side of this is this pressure washer was @ 1200.00 dollars. But it is a belt driven not a shaft driven like most pressure washers. If you have any question send me a PM. :nope
Hey would email a picture of your set up to me also. It sounds pretty cool.
Share this post
Link to post
Followers 0
